Rear main seal
Peeledpeas
I just replaced my rear main seal while I was swapping the transmission a couple months ago but it appears to be leaking already. Is there anything else that could leak that might look like a rear main leak? I can definitely see a stream of oil comin down behind the flex plate. I'm pretty sure I got a good look at the oil pressure sensor and it doesn't appear to be leaking. Kinda really annoyed about this. Was a Felpro seal set with cover gasket and I followed the instructions. 2005 GMC Yukon 5.3L
mountie
Ouch...... Something failed...... Get it on a lift..... clean the area good..... maybe you'll find it?
Sorry to hear, you might have to do it all again..... Bummer....
justirv
Installation of a LS rear main seal can be problematic. Did you use any type of alignment or installation tool? Something like the Sac City tool, which will align the cover and seal to the block. If you find this (rear seal) is the problem, I highly recommend one. Good luck.
P
Peeledpeas
I was unaware of needing an alignment tool. There was a round plastic thing that came in the Felpro set but I take that may have been inadequate for the task?
drdave81
Waterford, MI
That's not an alignment tool. It's just to keep the seal surface intact. The alignment tool is usually aluminum. You remove the old seal and then when reinstalling the cover, place the tool in where the seal would go. Bolt everything in place and torque. Then you install the seal last.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
I never heard of this alignment tool for the rear main. Is this all LS motors?
latvius
Ariton Alabama
latvius
Ariton Alabama
Yeah it is an alignment tool, just not a great one. Below is how Felpro describes the seal
drdave81
Waterford, MI
I didn't realize there would be that much wiggle room on all the bolts. Do you have to do the same thing with the front too?
There are alignment tools for the front and rear covers. If the oil pan is off, you need to align the covers both up and down, as well as side to side. If the pan is still on, then they only need to be aligned side to side. I've never used one for the front cover, as I have an old harmonic balancer that I took a grinder to the inside of so it will fit snuggly, but slip on and off. That's my alignment tool. Since the covers can move side to side, you can have excessive pressure on one side of the seal, and a lack of pressure, causing it to sit incorrectly and leak.
I've never had to align the rear cover, since if it's not leaking, I'm not messing with it lol.
89Suburban
SE PA
Wow good to know, appreciate it.
latvius
Ariton Alabama
" If the oil pan is off, you need to align the covers both up and down, as well as side to side. If the pan is still on, then they only need to be aligned side to side."
This makes no sense to me, the alignment tool puts the cover equal distance around the crankshaft, you're not going to be moving the cover side to side. You could rotate it a bit but once you have all the bolts in it would be very minimal.
Have you used an alignment tool to install the rear main?
drdave81
Waterford, MI
Right, I meant without the alignment tool, the cover can move side to side and have the seal sitting offset left or right.
And yes that video shows him keeping the plastic piece in there, but if it basically falls off, how well is it really aligning anything? If it worked for him, cool though. There's also people who have installed covers without any tool and not had a leak. I'd also not advise that, but it's been done. People reuse TTY head bolts and are fine........ It comes down more to a luck of the draw.
Then there's people who don't do things the correct way and have issues.
strutaeng
Dallas, Texas
I did the rear main seal like 3 years ago on my 06 Suburban. I bought the Sac City tool. I followed the instructions centering the cover, then installed the crank flange seal. Torqued everything.
Then when I got back to my workbench, there was the cover gasket! LMAO
So I had to remove the cover and reinstall it, which kinda negated the centering tool because I had already installed the round seal. I just torqued the 2 smaller long bolts to the same specs, which was like 108 in-lbs IIRC.
This spring I refreshrened the engine due to a lifter tick. I reused the rear main seal and I installed it again like that.
scottd
