The KidWagon
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
It's not enough for me to notice or bother me. Probably cause I'm running stock tire and wheels. Damn I keep forgetting to make that measurement. brb
89Suburban
SE PA
Ok center of wheel to fender lip:
Front: 16.5"
Back: 18.5"
KidWgn
KidWgn
Certified Kid Hauler
St. Louis, MO
Oh it does :rotflmao:
My fender to hubs are currently:
FL: 17.5
FR: 17.5
RL: 17.5
RR:17.625
1/4 tank of fuel
Front: 16.5"
Back: 18.5"
What the heck!? You're like a 5/4 drop, reversed. My stock measurements were 21.5F and 22.5R.
I wish @iamdub would come back and love us.
KidWgn
KidWgn
St. Louis, MO
Forgot to post this after I took off the door trim and badges!
KidWgn
KidWgn
St. Louis, MO
Welp. Broke another one of Trekline's bolts last Thursday night. It was one of the bolts that run vertically to hold the lower trailing arm's drop-shackle to the pad. I heard it break while backing into my driveway. After crawling under it, I realized that the other side was just plain missing.
THANKFULLY, I had already read about another company's arms, and ordered them a couple weeks ago. I much prefer the APOC Industries arms that I installed over the weekend. I didn't take any pictures of them side by side, but here's a link to their page.
I did the upper and lower trailing arms AND the track bar.
MUCH less noise, and far more comfortable than the Spohn arms. If anyone wants the Spohn stuff, I'll cut you a crazy deal on it.
kbuskill
NE. FL.
Link says 0"- 6" lift. Are they short enough to center the axle with your truck being lowered?
kbuskill
NE. FL.
I'm debating a 6" rear drop.
Do you bottom out hardcore? Debating whether I should put a C-Notch back there...
I lifted mine back up 2" all the way around after buying new tires that were too wide.
But to answer your question, NO. When I had the 6" drop springs out back nothing bottomed out after notching the crossmember where the panhard bar bracket on the axle would make contact if you hit a big bump.
I also kept the auto leveling in the rear though so she didn't sag from loading the truck heavy or towing.
KidWgn
KidWgn
St. Louis, MO
You TOWED at 6" in the rear!? That's goshdern impressive!
I'll be back out under mine this weekend. I'm going to cut the lips off the front fenders. I think I already notched the crossmember, or cut the tab off......but now I'm second guessing myself.
kbuskill
NE. FL.
I cut the tabs and the crossmember just to be safe.
And Yes, not a big trailer, like a 6X12 open trailer with, you know, "Stuff" on it... lol
I like keeping the Auto leveling because it is nice being able to load up all the family and luggage and cooler and whatnot and not have to worry about scrubbing fenders.
KidWgn
KidWgn
St. Louis, MO
I still have my sensors and whatnot. Did you keep the factory air shocks, or did you retrofit bags?
If you kept the factory air shocks, I'm assuming you're using a 4" drop shackle?
89Suburban
SE PA
Aren't drop shackles for leaf springs?
albac
