j91z28d1
Why is my post above with more pics waiting for moderator approval?
are your seats cooled? I can't see the holes in the pic, I'm curious because mine doesn't really have any air come out of them and I'd love to fix it if could.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
For some reason the official Dorman website has the wrong stud specs, and if you order what they say fits the heads of an LS you'll have a bad time.
I brought a manifold bolt into AutoZone to compare, and the "official" Dorman parts are 1.5 thread pitch, but an LS head is 1.25 (metric).
Why not the ARP bolts always recommended here? Just curious still trying to learn ways of the Jedi’s here I read about and compare notes.
j91z28d1
locking nuts on studs into soft aluminum threads.
arp bolts are nice but the aluminum threads are the limiting tq factor and nothing to keep them tight over time but tq. even if you used a split lock washer under it, the spring is killed by the heat over time.
the studs are 10.8 rated, crimp lock nuts, hex top for easy install and removal.
I personally use them over bolts on anything I need m8 1.25 on that they fit.
Random selection by the forum software. Don't take it personally. (I see that someone must have approved it, since it's no longer waiting.) If the message has a URL or a pic in it, the software might flag it.
Carry on.
Taking a break. I have the seat out and all apart and just got done cleaning the heat/cool pad that lays between the foam and cover.
After getting the seat disconnected and out of vehicle and all the trim panels off I realized I couldn't get access to one of the side tabs that holds the cover on because stuff was in the way and the seat needed to be raised, so I put in back in and plugged in the main harness and the side trim that has the controls so I could raise the seat about halfway up.
Found out that you don't want it all the way up because then part of the track blocks the latch that secures the main harness plug to the seat and you can't unplug it, lol.
BTW, these power everything seats are heavy
How come you grabbed all the change before taking a pic? ;)
St. Louis
There was no change. There were some old fries though and a crumpled up straw wrapper. I did get a pair of those "drop stop" things for Christmas 2 or 3 years ago and they help a lot. I've dropped my phone and keys before between the seat and console and the keys fell under the seat track and were a pain to retrieve.
89Suburban
SE PA
How did it go? Did you get her buttoned back up?
St. Louis
So I really didn't get any pics of the new foam going in, but that heat/cool pad that I removed from the old one is like small bubble wrap type of thing. It is a sealed bag with like a honeycomb type of string reenforcement inside. That port in the front goes through the seat and attaches to the black plastic air tube under the front. Attached to the top of this appears to be a sewn on cloth with heat wires running across. The wire loom is attached to the rear corner and runs under the seat.
I'm not too sure how this cooling thing works exactly. Either air runs through it and you feel the cooler air under your butt, or there are fine perferations on the top of it and the air leaks out the top through the "perforated" leather on the seat and you feel that on your butt.
Here are those pics again of the heating/cooling part on the seat.
Here's the port in the front of the seat
Here's the pad on the cushion. It was stuck down with 3 strips of adhesive tape that I carefully pulled it off of.
Tape strips were in front, middle, and rear. I have some 3m double sided scotch tape that I used to stick it down to the new foam before attaching the leather cover.
As I reassembled the seat I wiped down/treated the leather and also cleaned all the plastic trim surround that goes around the sides and back before reinstalling. Here's the seat before putting back in yukon
And of course I used this opportunity to vacuum where the seat goes
I have a brand new drivers bottom pad and bottom seat cover sitting here for like 3 years now, lol
seat feels fine I just have a small worn spot on the outside edge of the cover it hasn't gotten bad enough for me to change it out yet
that and a new steering wheel sitting here as well probably had that close to 4 years
one of these days,,,,,,,
Geotrash
Dave
Richmond, VA
With seat installed
I sit higher now. I use the seat memory presets and now I need to raise the headrest a bit and adjust the rear view mirror. The seat is adjusted all the way down. It's much firmer, but feels weird sitting up so much higher.
I noticed the same thing when I changed out the cushion and leather in my ‘07, but I like it. My cushion was from the seat shop as well.
j91z28d1
huh, so there's nothing between the air pad thingy and the seat leather with the holes? I was kinda hoping it would blow harder after replacing the foam. but it doesn't seem like it would make much difference except for maybe if the little holes in the leather were clogged up and could clean it eaiser being apart.
mine feels like the leather gets cold but no actual air comes out. I do get the hot air out the back, so I'm guessing it's kinda working but I'm not sure how the air is ducted around either. hmm
this really should be a thread of it's own, so the pics and surff don't get lost here.
j91z28d1
I replaced the foam in my c6 seats because I took a trip and 4 hours in my butt was over sitting on the flat bottom. after changing it, it sat so much higher my head hit the roof haha.
I had to pull it back apart and lengthen the cables they used as springs to lower it back down as much as I could haha.
Hodmjstone
