Intro & planning post
X-Factor
Maryland, USA
First post. Long winded - don't TLDR me please lol.
As a kid I grew up with Suburbans - learned to drive on an 89 GMC Suburban that my dad bought new - only new car I think he ever owned, a 99 Chevy Sub shortly after (we needed both - big family!). Since then I've personally owned a 97 (?) Tahoe, 99 Chevy suburban, and in 2018 I picked up a strangely low mileage (comparatively) '06 XL Denali with every option available at the time - still have the window sticker too. Every time I've NOT had one of these trucks, I've regretted it. So, I will be holding onto this one until the wheels fall off...
I've driven it all over the east coast at this point, she's sitting at around 150k miles - truck has been flawless aside from those pesky 20" stock wheels leaking like a sieve. Annoyingly frequent cleaning job is required on them to hold air. Aside from that....she's been a joy. Paint is heat damaged, changer hasn't worked since I bought it but I've been too lazy to fix it (yes, I still use CDs). Wife has since crunched the driver side mirror which is cosmetic but annoying damage.
Also since I was a kid, I dreamed of shoving a big block into a Suburban and making it a sleeper truck. The 454 seemed like the pinnacle of power to me in the late 90s, so while that motor isn't on my radar anymore, this beast of a 6.0 seems like a good alternative. While it won't be a "fast" truck for these days, it could be enough fun for my midlife crisis. I had to replace my muffler a few weeks ago and it woke up the old me lol. I have a vision for this truck, and since I don't have fast cars anymore this itch might need to be scratched. I'm no mechanic, nor will I pretend to be one. Here is my plan, as I start to sketch out the path:
Power:
compression/sonic checks first
Intake
Headers
full exhaust
fuel system?
Tune - what is the move here?
I was told (and have seen here) to not open the block until its really necessary so no intentions there. Probably need to understand the upgrade path there as well.
Transmission:
Upgrade the 4L65E to 4L80E - no shifting issues but she's a little sluggish and I don't think will like more power.
Rear diff?
Not sure what all is needed here that makes sense....who is the best in this realm? I had reached out to Monster Transmissions but haven't connected yet.
Interior:
replace changer
slow project to turn interior into a sleeper cabin - long term project.
Exterior:
Swap the 20" wheels with 17/18s - anyone know the stock 20" wheel weight? Haven't been able to figure this out, would like to know so i can make sure I'm maximizing rolling resistance reduction.
Tint front windows
Bull bar
Probably respray the whole truck either the stock silver or a matte gray. Not sure.
Thanks for reading - she's an older beast now but man I love this truck...
Good plan. Those wheels were GM Accessories for the generation after yours, 2007-2013.
If you put the 4L80, then you'll probably want to change the gears to 4.10 or lower ratio.
X-Factor
X-Factor
Maryland, USA
Ahh good to know. They look good (better than the Escalade wheels - eww), but aren't in great shape now. Heavy and corroded sadly. Not wheels i would have chosen.
X-Factor
X-Factor
Maryland, USA
Looking at my build sheet from compnine it appears that the 20" wheels were factory. perhaps not THESE 20" wheels, per se, but my truck had them originally.
Mudsport96
40.923,-89.488. Illinois
Power:
Compression check is a good start. To sonic check the block it has to be disassembled so skip that
Tube or manifold? The stock truck manifold is about perfect for these trucks maybe the Trailblazer ss intake beats it some, but not worth the effort if you aren't going wild
If you go headers get long tubes, shorties don't give enough power back for the cost and work to do them
full exhaust
Will be required for long tubes anyway
fuel system?
Maybe new injectors but stock flow rate should support most of what you do.
A tune on a stock engine is worth some, but if you do headers you will want to get one. Contact Blackbear Performance they are a sponsor here
At this age, I would consider replacing the oil pump Oring on the pickup tube. But that can be done with the engine in the vehicle. It is kinda cramped, but I did it on my z71 so I know it can be done.
Transmission:
Will require a tune anyway so that should be on the list. You will need the 4l80e flexplate and either rewire the harness or by the conversion harness. Then an adapter for the tcase if your rig is awd or 4x4.. also driveshafts.
Rear diff?
Not sure what gears you have, but 4.10s are nice if you don't run 80 mph much remember if you have awd/4wd you need a set for the front too.
Not gonna lie, if you can find a donor truck for most of the parts or junk 80e online.... use it as a core and get an Orielly reman if you have a store close. In person warranty stuff is soooooo much easier than dealing with an online person. And unless you are pumping stupid hp numbers a stock 80e will last behind a mild 6.0 forever. They came behind the 8.1 and I believe early duramax. I know the early 80e in my dad's old 6.5 with marine injectors and bigger turbo was fine. It didn't make a million hp but it was always overloaded by about twice the gvw lol.
Interior:
replace changer
Exterior:
Tint front windows
Bull bar
X-Factor
X-Factor
Maryland, USA
Great input! Thanks so much!
Welcome to the Forum from NH.
Pics of the truck, please.
That is a VERY nicely kept truck. I'm sure that you are proud of it.
Matthew Jeschke
Sahuarita, Arizona
I built up a 4L60E and zero regrets. They can be a strong reliable transmission...
I also built a 6.0L. Bought all the parts and assembled it myself with custom valvetrain. However with $$ I have into my build for like maybe $1000 more I could have done a 7.0L. If you want a super fast sleeper go with the 7.0L.
The rear end... not sure is that a 14 bolt already? You don't need anything more than a factory 14 bolt. I have the stock 10 bolt with no issues and a 6.0L. Been looking for a 14-bolt junkard special but haven't found one.
I tuned truck myself using HP Tuners software and wideband. Fuel is somewhat straight forward to tune. Speak, you may like to take into a shop to do but if you're feeling adventurous enough can do it yourself.
The 7.0L may require different fuel aystem... a likely comparison would be the 8.1L big block suburban... I'd look at what pump and lines it has. Although the 7.0L can easily be configured for 600HP or more. I think the 8.1L is much less.
Been on this journey building a mountain climbing beast for about 7 years now. Lots of help from forum here.
TexasTaz
