SilverSurfer5300
- Joined
- Apr 18, 2024
- Posts
- 21
- Reaction score
- 70
So, I'm about to do a thing. . .
Setting three (2.2" lift on this application) to level the front with the rear.What height? Let's see it!
Yes.Is that the oil drain plug? Makes it easier to drain?
I have not installed one on the Yukon yet but all my other cars have had them, except for the one that is slightly lowered and there is no cover protecting the drain plug area.My first time to change the oil on the [new to me] Tahoe. I put these Fumoto valves on every vehicle I own. I've been using them for 10 years without any trouble whatsoever. I absolutely love them.
Installed 5” rear springs today so officially at 4/5 drop now.
View attachment 428729View attachment 428730
Mine do that periodically too.Ok I got a post here that is blocked and needs to be approved by a moderator for some reason. @07Burb @Fless @Miami-Dade @NathanJax @soulsea
What is the torn metal in the last pic?Ok I have been having an issue with a bottoming out in the rear with the 5" springs after they settled for about a week. Only at a few choice dips I got to hit is when this happens. I was not able to find ANY visual evidence of contact at the suspected locations:
Panhard mount to frame
swaybar to panhard
axle to frame (free travel mod done)
axle pumpkin to cross member
So I figured it had to be the factory shocks bottoming out. I ordered the 2410FF belltech shocks and put them on this weekend. Huge improvement in the ride, but I still feel a bottoming out at the usual suspect dips. This is driving me nuts.
View attachment 429651View attachment 429652View attachment 429653View attachment 429654View attachment 429655
thinkin that was from a fight with the free travel modWhat is the torn metal in the last pic?
Or surgical rust.thinkin that was from a fight with the free travel mod
mine hit the bump stops and then the axle side panhard bar mount, both those pics in yours looks fine, you should the springs are seated in the top and stuff like that?
Don't look at thatWhat is the torn metal in the last pic?
mine hit the bump stops and then the axle side panhard bar mount, both those pics in yours looks fine, you sure the springs are seated in the top and stuff like that?
