LordWayback
- Joined
- Jun 23, 2022
- Posts
- 516
- Reaction score
- 404
Have a nearly untraceable evap leak? This may be the solution in all my time working on 5.3 gm trucks/suvs have I seen this part fail
View attachment 421084View attachment 421085
being honest unless it’s really loud I will not hear Anything out of the ordinary over the modified exhaust, I was purchasing a fuel pressure regulator because i heard that it could cause a evap leak and checking the one I bought to see if it’s close to the one i bought and boom I see that giant crack also to note I have the lightest no CEL misfire and smell gas sometimes and only will get a CEL after setting the Evap monitor and when I do it’s a generic minor evap leak on a freeze frame it used to be 2 evap leaks but i replaced the intake evap vent valve this piece may cause a misfire aswell as a fuel pressure regulator leading me to believe that this may fix my smog issue on the evap monitorWas that your only fail/DTC? Could you hear it?
My only DTC is P0440 generic minor evap leak on a computer freeze frame so a minor leak could just be this or a fuel line that’s rotted/not connected properly or my charcoal vent canister next to my tank which I need to install may be failingWas that your only fail/DTC? Could you hear it?
Did you type that all in one breath?being honest unless it’s really loud I will not hear Anything out of the ordinary over the modified exhaust, I was purchasing a fuel pressure regulator because i heard that it could cause a evap leak and checking the one I bought to see if it’s close to the one i bought and boom I see that giant crack also to note I have the lightest no CEL misfire and smell gas sometimes and only will get a CEL after setting the Evap monitor and when I do it’s a generic minor evap leak on a freeze frame it used to be 2 evap leaks but i replaced the intake evap vent valve this piece may cause a misfire aswell as a fuel pressure regulator leading me to believe that this may fix my smog issue on the evap monitor
I’m known for that.Did you type that all in one breath?
I’m known for that.
