Darn, I was hoping you were going to say you had the BB tune and it passed no problem.
according to them it should, next time around I will find out for sure sometime in early 2025, unless it's been 2 years already then it would be around march of next year
RooTBeeRthe1st
Unless they look at more stuff or look deeper in CA, I never had a problem passing with my rear O2 codes turned off. All readiness monitors set just fine.
Supposedly a year or two ago, they started checking that you have a stock tune or at least one that was made smog legal like the one I have from Whipple.
When I had to get smog last year, I was just going to leave my HP tune on it just to see, but I actually ran out of time and so I just flashed it to stock knowing that it was going to pass no problem.
RooTBeeRthe1st
Only the past two years. Had O2s and other things turned off in '17, so I've passed four emissions inspections with it, the final one in '21 with it cammed/modded with no cats. No visual inspections here although that's easy enough to pass. I don't believe they've changed anything in the testing.
You passed well cammed and catless?
Yeah, visual is also what can get you. Because even though the computer says everything's happy, they could see you did something that's not supposed to be there and being a hole about it and fail you.
ya, I just gave the smog guy the hypertech box with the carb number on it, I don't know if they would have detected it otherwise or not
I recall that being discussed. Didn't know it was put into action. Damn.
Cammed, catless and tuned to exaggerate the idle lope rather than smooth/hide it lol. No visual or butt sniffs here. They test the gas cap seal and plug in to the ALDL to check readiness monitors.
For visual cat test, I'd just run exhaust tubing through the stock cat shell. It'll have the proper numbers on it and will just look like an OEM replacement cat was installed. Maybe go a step further and drill holes in the tubing and pack the shells with steel wool so they'd at least have some active function as small mufflers. Still, you can't beat the butt sniffer.
I'll just have to enjoy my freedoms while I still have 'em.
Just Fishing
Can't fix stupid
Utah
Changed the low beams with Sylvania xtra vision bulbs.
Not too difficult of a job once you know about the side bolt in the wheel well.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
:thumbsup:
I have a 1/4" drive thumb ratchet perfect for that bolt. And you only need to loosen it, not remove it. The slot in the tab ear is an open slot.
St. Louis
Years ago to pass a visual we used to hollow out the cats by taking them off and ramming a piece of rebar or pipe into it to break up the honeycomb inside and shake the broken up pieces out.
My '33 and '95 don't have cats. They're both old enough to be exempt from emissions, even though the engine in the 33 is a GM 350 crate motor from 2010
All the ones I've done, they stayed on the vehicle. Just unbolted the cat-back pipe and wired it to the side and took a hammer, pry bar, large screwdriver and whatever else would fit in the hole to the ceramic. Periodically start the car and rev it to blow out the dust and chunks. Repeat as necessary.
You ever think about all the cats you've hollowed out over the years and how much money you threw away and/or what chemicals and elements you exposed yourself to? :D
I only think about the money I've thrown away.
justchecking
Military
SW Ohio
I finished replacing the four (correction)>> passenger side spark plugs. The @Rocket Man socket setup worked for #8. Took me 65 minutes and gave me a headache. And more appreciation for @OR VietVet who is older than me but still turns wrenches. ;)
Just Fishing
Can't fix stupid
Utah
a really good leaf blower works great if they are off of the vehicle.
always that floof thing that wants to stick in there, but leaf blower = launcher!
Just Fishing
Can't fix stupid
Utah
This makes me glad that my state requires everyone to carry zero-deductible glass replacement insurance.
Made me think of my Jeep, it came with a cracked windshield.
I could have blamed it on that guy that hit it, it's a $340 windshield, I even had a neighbor ask me and say "well heres your chance (wink)"
Fraud came to mind right off. :rolleyes:
yup, it's still cracked.
Glad we don't do safety inspection right now!
JohanZ
