Transmission Removal
bonnie
Question. I have 2006 2wd Yukon 5.3 that is in need of a rear main oil seal. I have been told the the trans and exhaust must be removed to do the job. Question is there any other path besides removing the exhaust? I just worry about the exhaust bolts breaking off where it bolts to exhaust header.
Nice design GM
strutaeng
Dallas, Texas
I think just about any exhaust in any other rwd vehicle would require you to remove the exhaust, no? Heat and penetrant oil are going to be your friend.
I did the rear seal last year on my LQ4/4L80e/2wd suburban. I had the bright idea to replace the front pump seal and lock up o ring on the transmission "while I was there." Of course, the local parts store gave me the wrong pump seal, so I had to go hunt another one at a different place. But putting damn heavy torque converter back was the biggest pain. I was working under the truck and had lift it over my head while the transmission was on the transmission jack. My upper body ached a good few days :confused:
D -money
Ditto, i applied heat cycles with aerokoil for a week and prayed a lot with some sweet talk during the operation to remove without breaking anything.
strutaeng
Dallas, Texas
Good to hear that!
"I" would have done a lot of cussing in English and Spanish! LOL
Anyways, did you buy that rear main seal centering tool? They have different ones. I bought the Sac City version. I posted their link somewhere that shows how to replace it.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Nice design GM
How badly rusted are they? Do you live in a "salt on the road" state. Lots of penetrating fluid for many days and heat works well. If you can reach them, use a wire brush or wheel to clean the exposed threads as much as possible before removal. When you do attempt to break free, do so and back out just a little, then retighten and spray more fluid and then loosen just a little past the first attempt and then retighten and repeat a little at a time. If moves freely at any time, spray fluid and take out. Tap threads and holes before reassembly.. If you are on your back, get a transmission jack somewhere. If you are keeping, get the transmission gone thru if can afford.
D -money
Good to hear that!
No ,im a frugal cheap ass who mcguyvers whenever possible.
B
bonnie
Thanks for all the reply's, in most cases I really like doing the work my self but after reading your posts I think its to much for me, especially if things go wrong then I really have a mess. That's a lot of physical work to do on your back in the cold. When the money is there I`m shop bound. Local Chevy dealer says $800 so I`m in!
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
I used to bench press NP203's into place when I was in my 20's. Now my sorry old ass can barely handle climbing underneath to do an oil change.
For anyone that does climb under to work on the vehicles, my saving grace is a roll out pad that my girl got for me. They are 4'x8' and about 3/8" thick and are foam feeling and tough. I have set jack stands on them and used a floor jack on them. I use 2-3 at a time and is quite comfortable. I also use kneel down pads that are thicker. It has saved my 70 year old body.
Yeah I did my 4l60 in my 02 3 times after age 55. I don’t want to ever do it again. It’s super hard without a lift, especially if there’s a transfer case involved.
albac
