The KidWagon
kbuskill
NE. FL.
Thanks, I cheated on this one and bought a pre-made light. The one I originally built sequenced from the center out with turns and brake lights but I kept having issues with the sequential modules so I finally removed and replaced that one.
I should probably clarify, the internals I bought, I still had to open and install it into my existing light.
KidWgn
KidWgn
Certified Kid Hauler
St. Louis, MO
Spent some time cleaning up two of the wheels today while I had them off. I can’t believe how neglectful the previous owner was. They were so dirty, I didn’t even realize there were machined pockets on the sides of the spokes. (Clean photos are screen grabs from a video)
Here’s one I hadn’t cleaned yet:
I’ll post a photo of the whole truck with the before and after tomorrow :)
KidWgn
KidWgn
St. Louis, MO
And turned a street corner on ~32" tires? Not without a lot of fender well modding. @Doug118's is static dropped a little more than most here. Maybe he can give you a few pointers.
I wasn’t serious. I had just installed the front coilovers, guessed at the height, and then loaded all the weight to the front to settle them. In the previous photo, the rear is jacked up by the hitch, facing downhill. I skinned the tire just pulling out of the driveway to turn the truck around :anitoof:
After adjusting the height, we ended up something more like this:
Comes out to right at a 4” drop up front. I still need to do some tweaking. I also need to do the free travel mod still. I ran out of time last night. I’m hoping that will allow the rear to settle another 1/2”, and I’ll be happy. I may end up looking for some Jeep springs for the rear, thanks to a wise wizard :)
KidWgn
KidWgn
St. Louis, MO
Still having an issue with a rear end "shake". I thought it was the OE wheels, as one was bent. That's what started all this modding. :boxed:
The truck has now shaken the SECOND bolt loose from the trailing arm drop shackle; the vertical bolt that stops the shackle from moving up/down.
So, to remedy all of this, when I ordered my Spohn panhard bar, I went ahead and ordered their entire kit with adjustable upper and lower arms as well. Will be installing this weekend. Any advice from the pros on starting settings? From what I'm picturing, I think I should shorten both? My end goal is to get the axle centered into the wheel wells, and use the panhard bar to center left to right.
Describe the shake. Changes with speed? Is more intense within a particular range of speed? At low speeds and light braking, does the brake pedal pulse?
You would lengthen them, not shorten. The difference is about 3/8"-1/2". Or, just measure the fender opening to the edge of the wheel lip, tire or hub center and determine how far back you wanna relocate it.
If you have a really good eyeball, you can set the new arms by just measuring them against the stock ones. If you wanna ensure repeatable accuracy, a cheap way is to use a stock control arm as a guide to drill two holes in a straight piece of 2x4. Get a drill bit that fits snugly through the bushing eye to center it as accurately as possible and hold the bit/drill perpendicular to drill straight. Drill through the board and tap the bolts through the board with a hammer. Mark the side of the board the bolts extend from (opposite the bolt head/entrance side). A line across the length will do. This will be the "top/surface". The bolts will be spaced the original distance of the control arms. Cut the board in the center. Place the short edge of the 2x4 against the short edge of another 2x4 or 4' level or something straight and rigid. Spread the cut halves apart so that you have a 3/8" to 1/2" gap between them. The point of the drawn line is in case you get one end of the cut 2x4 turned around, you'd have a reference to properly orient them. Clamp the halves in place on the straightedge. You now have a jig to adjust the new control arms to whatever amount you wanna lengthen them.
Adjust the uppers by the same amount and install. Then, adjust them as necessary to dial in the pinion angle as it has likely changed some with the drop parts.
KidWgn
KidWgn
St. Louis, MO
It happens between 65-75 mph. The intensity is sporadic, but it FEELS like a wheel out of balance. It's a left to right shake, for sure, not a "bounce". Doesn't happen at all during low speeds or during braking.
Very great idea on making the jig for repeatability. I'm a machinist by trade, so I have all kinds of handy measuring tools; I'll probably just measure them with a 24" ruler down to the hundredth. I wish I had access to the machines at home, that I do at work. I work for Boeing, so it's pretty frowned upon to bring in "home projects" lol.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Guy I work with worked for Boeing in Philly eddy stone
brice715
