the 18th letter
Northern New Jersey
That's what happened with my 05 Express van. I got so many random misfires(P0300)that it eventually clogged one of my converters. Iirc there's 2 converters---so I just hollowed out the clogged one. No more random misfires.
Being that I've floored it in this same stretch often over the years and only got a shudder once a couple years ago when I got past 90 and this is my first time using seafoam I'll keep my eye on it and refrain from further seafoam treatments.
the 18th letter
Northern New Jersey
Or you could refrain from driving illegally and unsafely.
The rare 20 mph over the speed limit is about as illegal as I get these days but no one was on the road at 5am, no one was put in danger. I always step on it before I change the oil so hopefully it doesnt come back next oil change.
Mean_Green
Walked past it in the garage and noticed the left front tire is quite low. Will have to air it up before the next drive. No idea what shops charge for flat repair on this size tire.
OK, so almost two months and it's low again. Clearly not a major leak, but what, puncture/object, rim or valve stem? Seemed to take quite a while to air up last time, like it didn't want to take air easily, but that could have been the adapter I was using on the air hose.
Mean_Green
Drove it for the first time in a month. Rode smooth for the most part, some minor vibration at certain speeds. Gets up to 80- far too easily. Didn't even notice a couple of times and had to back off some.
Temp never got above about 160-170, but air temp was in the 40s. Volt meter stayed just under 14. Oil pressure around 40.
97YukonNZ
Got my aircon going yesterday after 2 years of no connection.
Had a repair done on the inlet manifold a couple of years ago and the mechanic bent the pins in the plug.
I finally succeeded in straightening the pins with it in place and We have cold air again!! :favorites37:
GMT800 2005 Tahoe Z71
Navy Supporting Member
I finally succeeded in straightening the pins with it in place and We have cold air again!! :favorites37: View attachment 417390
Just in time for winter.....perfect!
Mean_Green
Cranked it up, pulled out of the garage and hooked up the trailer for a dump run tomorrow. First crank, got the starter free spin again. Second time that happened. Cranked it again and it caught fine and started easily.
Starter failing, or not unusual?
97YukonNZ
Just ordering some 2" drop hangers and 2" drop keys for the Yukon.
Summit racing for the keys and Switch Suspension for the hanger drop kit.
The big girl is coming down!
Boss gave me a k towards some 20's n tires so I'll be shopping for those.
Going to replace the 2" body lift with new stock height replacement kit as they are old and hard. Think they are putting vibrations through the rig and causing some driving flex in handling.
Time to black her out :favorites37:
j_jerry79
