A Sticky for New PPV/SSV Owners To Re-Civilianize Our Tahoes
marcello1395
In a way, I'm glad to know that I'm not alone. But it certainly sucks. I have purchased the following and will be trying them out:
(8*168gb model)
I'll post a write up on them after I get them installed and evaluated.
Definitely let me know still debating which one to go with.
Jimgeorge
Florida
Thanks for the info. I just ordered a new leather-wrapped civilian wheel from the dealer. I guess I'm becoming a frequent customer because the price dropped to $186. Some of these OEM prices are fantastic.
I received the civilian shift lever. Do you recommend any other interior upgrades? Can I upgrade to automatic HVAC controls?
Does anybody have a part number for the civilian shift lever.
A1251R
St Louis, Misery
Fixed this as follows below, hopefully you can do similar or find a better solution:
Removed tail light assembly. Found that the brake light is the light blue wire going to the top bulb in the terminal marked "Major".
All the tail light wires including the light blue brake light wire trace to a harness going into a TFCM near the spare tire, which is a Trailer Brake and Fuel Pump Control Module.
No voltage on the light blue wire after the TFCM to the tail light when the brake is pressed. But on the front side of the TFCM the light blue/white wire reads 12v when brake is pressed.
So I jumped a splice clamp from the light blue/white going into the FTCM directly to the lightblue wire going into the "major" terminal on the top bulb on eash side bypassing the FTCM.
And boom. Brake lights now working. Tail lights, turn signals - all good.
Edit: Total cost $approx. $10 for splice clamps, 18 gauge wire, and wire conduit
Edit #2 4/9/18: After going through all this above I found a better solution. A number of wires at the BCM contained aftermarket splices. I removed the aftermarket splices at various BCM terminals, restoring the factory wiring. And now the brake lights work from factory wiring without the mess I described above. This includes the top center light bar, also needed to place a 15A fuse in #49 under the hood. I hope this helps, either method will get you there.
Is there a way to "unclip" the BCM harness to remove wires, or you were seeing aftermarket splices on OEM connections?
I have to take a better look at my BCM. I have the same brake light issues-been trimming/pulling the rats nest of wires from under the dash/headliner/etc. 2011 PPV Georgia K9. Also-what top center lightbar are you referring to? Your rig came with sirens? or just the 3rd brake light? Any advice greatly appreciated as I am tired of fooling with this for weeks now.
scoobydoo
*****PLEASE FEEL FREE TO MSG OR POST ADD-ON'S TO THIS LIST, ANY LINKS OR INFORMATION IS GREATLY APPRECIATED!! *****
I think we should have a sticky at the top of the PPV and SSV forums, with the basics about getting our trucks back to a more "civilized" form. We can also have a breakdown of the differences between civilian tahoes and PPV and SSV + other Fleet optioned vehicles.
The goal would be a comprehensive list of the basic stuff we all (or most of us) encounter when we bring our Government Owned Tahoes home with us for the first time.
Some topics or examples are:
- Rear Door Locks - Getting them to lock/unlock and have the ability to auto lock or unlock via Key fob and front passengers buttons
- Basic how to on all essential maintence to do when first getting the 'Hoe home like liquid; Oil, Coolant, Steering fluid, Brake fluid, Differential fluids, Transfer Case
- How to Make Rear Door Interior Door Handles Functional
- Radio swap for USB+BLUETOOTH+6 disc (XM undelete?)
- How to get 2nd row speakers working (mine are plugged in at the speaker but must be disconnected somehow between the B Pillar and the head unit as they do not function, makes me wonder if adding the small tweeter speakers on the upper rear C pillars would be plug N play since the rear passenger door speakers don't work and are plugged in )
- How to make electronic rear windows workable by the rear passengers (mine were disconnected, and each rear switch was taped over on the actual PCB board where the switch makes contact, but when switches were fixed and felt "right" the windows still only roll down from Driver's control, this leads me to believe the entire harness for each rear door must be disconnected because the rear speakers also don't work)
- Center Consoles with all the different options
- How to Add DIC button
- How to Add a Self Dimming and other features rear view mirror
- Floormat & cargo area options + model numbers
- How to remove spotlight and make civilainized
- How to swap steering wheels with radio controls
- How to swap front cloth seats for better options
I also know there are a bunch of mods that are much more than just simple plug N play mods such as:
- Folding+Heated+Signal Side Mirrors
- Rearview mirror with LCD built-in license plate camera
- Front Heated Seats, Rear Captains Chairs, Third Row Seating?
- Adjustable Gas Pedal ?
- Adding Carpeted floor & Replacing/Adding vinyl flooring
- Adding stock 8 speaker system components + aftermarket audio
- Adding rear climate controls on headliner (manual and automation)
- Adding rear heated seats
- Adding rear radio functions
- Adding civilian center consoles
I know I'm forgetting a bunch of stuff but do you guys think this is a worthy endevour? As a newbie myself (less then a month owning) I'll tell you I could really use a thread like this, to this day! A lot is info I don't have an need to learn/find and other stuff I'd be willing to write up.
Please help lol
Hi new to the ppv world and I just got a 2010 chevy tahoe LS 2wd ppv and there a whole bunch of stuff cut was wondering if anyone knows what's these for?
Nutro
I have RPO AP8 for remote start and just ordered (2) of the 22952176 remotes but now I am seeing that I needed the 22951509 remotes? Can anyone confirm the correct ones?
Sgt__Z
Charlotte, NC
I have been working on my 2011 Tahoe SSV and I have the same cut cables that you show in your second picture. I have been wondering what they are for also, but I have been dealing with other priorities at the moment. LOL.
Edmar2277
Some of this stuff is probably not economically feasible to retrofit, after all this is why we buy ours to begin with, I saved ten grand by not having all that ******** that is unneeded. If you find the need for all the goodies go buy one with all the bells and whistles.
To add some of that stuff you are going to have to change wiring harnesses. Forget adding OnStar and Bluetooth. Rear seat a/c controls and rear seat entertainment, forget that also.
I agree maybe a sticky for the basics, like a DIC and a Steering wheel, Easy stuff and cheap. Door locks and window switches, also the wiring diagrams that are in the police manual supplement. Those will help with the horn, front speakers, roof light and flashing lights.
adding a console is easy if you can operate a ratchet.
As always this is just my 2cents
How about getting the auto headlight switch to work on auto?
mikez71
You might have a resistor wired under the light sensor...
PIT#4328b
Procedures to disable to auto headlamps:
Unplug the ambient light sensor and put a 600 ohm resistor in place of the sensor. The resistor will command the TBCM to turn the auto headlamps off. The headlights will now have to be manually turned on with the headlight switch.
Secure the resistor and connector to prevent rattles.etc.
Vehicles equipped with Automatic HVAC (RPO CJ2) may have a light sensor that also includes the sunload sensor for the HVAC system. Make sure the resistor is wired into the ambient light sensor signal wire (Circuit 278) and ground (Circuit 1851). This can be achieved by backing out pin 2 at the light sensor and removing the terminal and adding the resistor to the wire and then splicing the other end of the resistor to the ground wire 2 inches from the light sensor.
Drewphil
