It's a 6L80, so I'm not sure. The fluid poured out through the inspection cover area, and even after sitting for half a day, it's still steadily leaking out. I have 180k on the trans and it's original, but with a circle D 2600 stall converter. I didn't think 6L80's puked the front pump seal like the older 4L60'swonder if the case broke or the front pump seal blew out.
that's sucks..
Yeah, that's for sure! But even before this happened, I have all of the typical failing 6L80 symptoms. I haven't heard of many pump seals blowing out on these transmissions, I'm anxious to see what happenedit won't move without fluid
so the alt I ordered a few months back when I am dub was upgrading his got canceled. it was an acdelco thru summit racing and after delaying a few times they said manufacturer isn't making them anymore.
need to go visit his thread to get the part number again and find a different place or go used.
I was seeing a steady supply of low-mileage take-offs on ebay. It's an alternator and likely to run for 200K+ miles. 10K-20K on one is just a drop in the bucket. Can't beat an OEM alt for $120.
I don't even remember what the pricing was on this one, it's been to loog haha and they never billed till it shipped, which it never did. I wasn't in a hurry and it must have been a good enough price to not go ebay.
I did a quick search. few on there for 160$ these days. I guess I'll keep an eye out.. gm parts direct lists one for 166. but tax and shipping it's probably pushing 200$
Sorry to hear that Mike. On the bright side, now you can build it up right and not have to worry about for years and years afterwards!I spent 3 days claying, compounding, and waxing. Also fully detailed the interior....and I didn't get pictures....because......
My transmission finally blew up... And spewed trans fluid ALL OVER the undercarriage and rear hatch. There was fluid POURING out of the bell housing area and just before it all happened, it had a NASTY downshift, then I saw white smoke out of the back, and then lots and lots of slipping. It doesn't move at all now![]()
I'm going to list my plans for the trans on my build page, and ask Nick, as well as you all, for advice on a few of the parts I'd like to toss in there. I figure even if it's just the pump seal that blew out, there is going to be other damage inside since I have lots of miles on it.Sorry to hear that Mike. On the bright side, now you can build it up right and not have to worry about for years and years afterwards!
ThanksSorry bro.![]()
sucks mikeyThanks
I knew for the last 1 year or so that the trans was failing. I never thought it would break in this manner though, haha.
My wallet is still recouping from the LS9 cam swap in my G8 I had to do earlier this year, which had an AFM lifter get stuck - with only 44k on it.
The price may have gone up due to the ramp up in purchases. I missed a couple cuz they were bought out from under me. Someone's scooping these things up! I was seeing them for $90ish to $110ish, $120-$130 total with shipping. There are a few (three, I think) different part numbers that will work just the same, so you have options. I was kinda wanting one with the clutch but I'm not sore about not getting it. I think I have the part numbers in a post in my thread.
*EDIT* Ugh. Just scanned ebay. They're expensive now. If it were me, I'd probably go with this one.
Thanks
It is na, and My other half wanted it to idle as close to OEM as possible. Honestly, I love this cam. I read in the G8 forums that some people feel they lost low end torque, but I have yet to experience that. To me, it feels a little better than the factory cam driving it casually, but when you romp on it, there is definitely much improved top end power.ls9? G8?
is it na? how's that go? everything I see says it's a soft. cam in the mid range. but it really like the idea of a oem idle.
how did you do the brushless fan swap?OK.. you saved me the hassle of searching.. sold.
130$ shipped for a 220amp alt is pretty good. my oem one struggles and can't keep up at idle in this heat with everything on max. it's better with the brushless fan swap, but still falls to battery voltage after a few mins stuck at lights or drive thru.
I like the idea of the clutch, most of the new performance cars use them but back in 08 only the auto cars used them, not the manual. mines the manual plus I have a bunch of different size pulleys laying around to adjust. so normal is good.
now I need a pig tail haha.
