Can’t Fill Gas Tank
gunslinger
Charleston SC
2010 Escalade. Only able to get about a tenth of a gallon in at at time. Must wait for fill neck to drain about 10 seconds and go again.
I completely removed the large charcoal canister. The vent tube coming from the tank is completely free. I went to the gas station and had the same issue. Can I correctly assume the issue is not the canister or the evap solenoid? What more could it be?
I don’t know what obstruction could actually be in the fill neck. Im not sure if there is a secondary vent somewhere that could be clogged. I thought the vent going to the canister was the only one. Also the solenoid line appears to only be connected to the charcoal canister so I’m thinking it should be out of play as well.
Also the charcoal blew out everywhere when I blew air threw it. Hundreds of pellets. I read elsewhere this is not normal. Should I get a new canister anyway?
Help is appreciated, thank you.
B-train
At this point, you are in need of a new canister. You also need to drop the tank and blow out all the lines. Then probably put in a new GM purge solenoid under the hood by the intake. These can be a wreck, best to just start fresh
GMT800 2005 Tahoe Z71
Navy Supporting Member
Gonna say the same thing I always say about this problem.
1. There is a BUNCH of threads to search thru about this.
2. In most of these threads I see people try to replace on or two parts and still fight it all. Especially since you have pellets everywhere, I would just do a complete system overhaul. In many threads the OP ends up, after numerous attempts, replacing everything and then there are many miles of no problems.
gunslinger
gunslinger
Charleston SC
Was hoping dropping the tank wouldn’t be the solution. It is what it is. I ordered the purge solenoid, vent hose & solenoid, and charcoal canister. All GM parts. I’ll outsource a shop to replace the parts and blow the lines.
Hoping to avoid replacing the fuel pump, but I am worried about charcoal being in the tank at this point.
j91z28d1
not to add more money to the job but what's the mileage? it might be about time to do a fuel pump anyways, just to save the labor of dropping the tank twice.
bill1013
Air Force EMT/First Responder Firefighter
Waianae, Hawaii
Replace the pump while the tank is down.
Replace the pump now and you’ll save yourself time and money down the road.
I had a gauge problem on my 99 Tahoe LT. My mechanic pulled the tank and said the internals were good. I told him to change everything an start new. Pulling the tank is a pain and it’s time consuming. He assured me it would be fine. Fast forward a month later and the pump in the tank goes. I told you so. Long story short… he pulled it and replaced everything at his cost.
Can you blow the lines without dropping it? I was under the impression I was gonna have to drop it to do that.
There are pipes that connect to the fuel pump bulkhead at the top center of the tank. If you blow air into these pipes at teh points you can reach with the tank in place, you'll be blowing them carbon pellets IN to the pump and tank.
At 225K, if that pump hasn't been replaced within the past 100K - 150K miles, drop the tank and replace it. Then you can ensure that all the lines are clean as well as clean the out the tank. My pump worked fine beyond 200K miles but then I realized the level sensor was way inaccurate past 1/4 tank remaining. So, it pretty much can't be a loss replacing the pump while you're clearing out the pellets.
Oh- make sure the shop knows to use very little air pressure to gently blow the pellets out. They can blast 'em with full pressure to make sure they're clear after the low pressure seems to have vacated all the pellets.
j91z28d1
so what happens? the charcoal canister releases its pellets into the fuel system?
That's exactly what happens. The way I describe it is they're in a permeable bag, very much like how tea is in a "filter bag". With age or abuse, the bag weakens and ruptures. I, and others seem to have concluded that overfilling the tank contributes to this. The canister is the highest point in the system as it's to catch vapors. But, when the tank is "super filled", it get under higher pressures from the fuel being sloshed around while being heated. Also, the tank being bounced around during driving gives it a primer bulb effect. Liquid fuel is pushed up through the pipes and into the canister, soaking the "tea bag" and pellets. Vapors, etc. are traveling all over the tank and up to the intake manifold, carrying the pellets. I had pellets pour out of the pipe at the purge solenoid.
j91z28d1
That's exactly what happens. The way I describe it is they're in a permeable bag, very much like how tea is in a "filter bag". With age or abuse, the bag weakens and ruptures. I, and others seem to have concluded that overfilling the tank contributes to this. The canister is the highest point in the system as it's to catch vapors. But, when the tank is "super filled", it get under higher pressures from the fuel being sloshed around while being heated. Also, the tank being bounced around during driving gives it a primer bulb effect. Liquid fuel is pushed up through the pipes and into the cannister, soaking the "tea bag" and pellets. Vapors, etc. are traveling all over the tank and up to the intake manifold, carrying the pellets. I had pellets pour out of the pipe at the purge solenoid.
I guess I should add that to list lol.
I've seen trucks at work stall because the charcoal canister gets fuel logged from fuelers topping off tanks every few days on stuff that hasn't been run. and as soon as the Purge solenoid opens, vacuum sucks in raw fuel and they stall out.
but I've not had to deal with the charcoal coming apart. ugh.
I keep adding to my lists of things to swap at some point haha.
Them pellets are surprisingly light. They'll ride that vacuum stream uphill and collect at the valves.
I tried shotgunning my pipes out with 150+ psi. Big mistake. The pellets, being carbon, chip off in pointed-edge fragments. So, when they're shot through a pipe and come to the first curve/restriction, they collide, wedge and compact to each other, forming a blockage. I had to take my pipes off to bend and beat their curved parts on the concrete while lightly puffing air, alternating from each direction to clean 'em out. So, use very low pressure to move 'em out, then high pressure after you're not getting any more out to make sure the lines are clear.
Definitely something to learn from others' mistakes rather than your own.
It's always better to fix or prevent on YOUR terms.
09_4WD_YUKON
I fought this crap for the longest time. Not sure what exactly what fixed it, but had the lines blown out, changed canister and purge valve and solenoid, twice!!! lol, I do think the vibration from the 2 15s in the back helps as well!!! Good luck with, definitely a HUGE PITA!!! I was also told that the gas tank need changing as there are some non-servicable check valves in the tank that get clogged and cannot be changed, but not sure how true that is as I never changed my tank.
29tomt
Same problem on my 2003 Tahoe. My repair shop replaced entire evap system including wiring harness using GM parts and problem solved. It has been several years now. Seems I was getting a code also.
BadDaddy2003
