It seems there's a 50/50 split between them being 7.380" and 7.385". There's also explanations for why there are these two specific measurements: One is the full sphere dimension for the ball tip and then that .005" shorter measurement if you put the caliper over the holes. It's flat there, costing you .0025" on each end. Since the ball tips fits in the cups so that they're the actual contact points, my personal belief is that they should be considered 7.385" since that's the
effective length. But, it's such a minute difference when you're dealing with hydraulic lifters that have something like a .040" allowable preload range so I just round it off to 7.380" to make the quick math easier.
Even then, the cylinders vary a lot between the corner ones and those in the middle. I have it documented somewhere in my thread from about a year ago, but I ended up with three different lengths of push rods in mine to get them away from the minimum and maximum preload figures and to tighten the variance across all of them.
*EDIT* I couldn't let it go so I looked it up:
https://www.tahoeyukonforum.com/threads/growing-up-doesnt-have-to-suck.93510/post-1669150
