Battery drain on a 99 Tahoe
GMT800 2005 Tahoe Z71
Navy Supporting Member
Are you saying completely dead? You didn't say. The first place I always start is by unplugging the alternator and see if drain goes away. You can put a DVOM between the negative post on battery and the cable end and measure milli amps and post that result here. If alternator unplug does not take care of problem, then you start by unplugging fuses, while DVOM is attached, and see what circuit fuse stops the big milli amp draw. All this needs to be done with a completely charged battery. Make sure you don't have a hidden light on somewhere. Any work done before having this problem?
D
djfive45
Only a new battery. 1st one was put in last September, car sat for a month went dead. Took it back to autozone and replaced it about a month ago. Pulled the instrument cluster since I'm having issues there. Waiting on replacement. This tahoe came from MN. Also looks like some of the ground wires I've seen so far need to be cleaned up. Firewall to block and frame. Still looking for more
D
djfive45
Yes It goes dead after 4 or 5 days. Kept it on a battery tender before I pulled the cluster
D
djfive45
Are you talking about the fuses under the hood? The cluster guy I talked to said to pull the cluster if it still has a drain he mentioned some fuse under the hood. Have to go back and read which ine he said.
For some reason I can't see what OR VeitVet posted
D
djfive45
By unplugging the alternator and it doesn't drain battery does that mean the alternator is bad?
There are diodes internally in the alternator. They are designed to allow current to flow one direction. If they fail and allow current flow two directions, that can cause a draw on the battery. If you unplug the alternator and that stops the draw, it means you take the radiator cap off and drive a new vehicle under it and install the radiator cap and you are good to go.
NOOOOOO....it means the alternator should be replaced.
D
djfive45
Before I put a new battery in it last year I dod notice a clicking noise in dash about the middle and the CD player was making a strange noise and had a hard time ejecting a CD. Some kinda relay maybe?
D
djfive45
Hahaha. Thanks for the info,I'm not all that familiar with electronics. Enjoy the humor
Not judging, but it seems like you might want a more knowledgeable person looking at it. There are standard methods and tools for diagnosing (parasitic) battery draw and until those are used, it's just a crap shoot to find what's causing it -- if there even is one.
Oodles of YouTube videos on diagnosing parasitic draw.
D
djfive45
I agree .thank you for the help
Bentley95
