solli5pack
- Joined
- Jun 17, 2023
- Posts
- 277
- Reaction score
- 412
Hey everyone. I've been chasing an intermittent misfire on my 5.3 Suburban that I think I figured out but looking for some advice to confirm. So the truck only misfires first thing in the morning after sitting all night setting off the engine light and the stabilitrack/traction control off messages with white smoke coming out of the tailpipe. After running for a few minutes it clears up and runs fine for the rest of the day. Using the Tech 2 I verified the misfire to cyl 4 only. I eliminated plugs, wires and coil by moving them around and misfire stayed on 4. I haven't been able to check fuel pressure when it's running bad but later in the day it idles at 43psi which I believe is good for a flex engine and all the injectors passed the leakdown test with the scanner. Fuel trims also look fine. I took a shot in the dark and replaced the intake gaskets and thought I got lucky after pulling the intake and had oil pouring out of it which led me to install the new style valve cover. I ran great for a couple of days but the misfire returned. So noticing that I've been losing coolant slowly with no sign of a leak anywhere I decided to pull the plug on 4 first thing in the a.m. before running and I found coolant on it. As far as I know only way for coolant to get into the cyl is a failed head gasket or cracked head. Never really had any engine issues in the past and the truck never overheated so I just find it weird the gasket/head would go bad. I did a quick compression test on cyl 4 and it came in at 150 which I believe is good. So my next steps is going to be a proper compression test on all the cylinders and a leakdown test on 4 and see if I get bubbles in the overflow tank. I guess then I'll know for sure. Just don't understand why it happens only on first start up in the morning. Maybe it's a small leak and when the engine warms up it seals? and only cyl 4? Oil looks clean by eye but I did find sludge under the oil cap, picture below. Engine has 168,000 miles and not sure if it matters but I've been using a Range Tech AFM disabler since November. What do you guys think?
