Scott in AZ
Arizona
Drive thru the forest up to the Trailhead for some mountain biking. Days like this when it all comes together and the projects in the garage worth every penny and every minute.
S33k3r
Dallas, Texas
bought a pair of front outer window scraper/seals, two pass side regulator motors. already have all 4 new regulators i got them years ago just waiting for the day i needed them. one is dead. one is slow. one squeals.....
now to see how long i put off doing the work..... need to open up 3 doors replace 3 regulators and the 2 seals and i also got a new driver side heated seat, seat memory, pedal switch as every time it rains my heated seat comes on full heat and wont turn off. bet the shot seal lead to that BS. junk dont even touch the glass.
I've read that dust builds up on the circuit board, and shorts when it gets overly humid/wet. Might be able to reuse the existing switch after resealing the door
Scottydoggs
NJ
i was thinking the new seal might help. but then figured wet electronics. replace it....
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
Idler arm w/bracket and pitman arm came in early Saturday. Swapped them both out, got it aligned on Sunday. Was told I need to replace the guide pins as they where damaged, so need to get those ordered and get another alignment.
Also replaced the rear brakes cause they were squealing really bad, turn out the driver inner pad had uneven wear and the indicator was scratching the disc. All done now, let see what she decides for me to fix next.
Mudsport96
40.923,-89.488. Illinois
Edit. No hail dents so that is nice. Pulled the Stampede bug/rock deflector off of it. Not sure if looks right now....View attachment 398611
Update, first long road trip after removal of the deflector... no more windshield air noise at 75 anymore. Best mod ive ever done lol
915_Tahoe
HELL PASO, TX
What did I say!
This Hoe did it again, right after I gave her some love. Ended up getting a tire flat going home from picking up the kids from karate.
I thinks she's still upset at me for neglecting her for awhile.
Hodmjstone
