Walchit
I bought one for the gasser (just because), but really want one for my kettle(s). They’re just so damn proud of them.. I do have a kettle pizza though, and it’s pretty badass!
Yeah, $234 for a genuine Weber one sheesh. :mad:
A lot of guys run the "only fire" brand
It seals better than the older style weber brand ones that I have.
I got two rings and the little spike pieces and a motor at an estate sale. They came with a gen 1(stainless steel) performer for 40 bucks, and I ground down a spot on a genesis spit to use on one, and bought a cheap spit and motor for the other one. The only fire would probably produce more consistent Temps and use less charcoal, because mine just sit on some tabs and don't seal around the bowl of the kettle.
I want a pizzakettle, but I think I will just end up cutting a chunk out of an old lid for a diy pizza oven.
Walchit
I got a needle scaler and some "rust kutter"(phosphoric acid) to treat the rusty parts on my frame, I think I'm gonna try to loom these last couple wires and get started on the rust today. I'm debating if I should paint over the rust kutter or just spray everything down with atf/pb blaster mixture so I the rust comes back it isn't under a layer of paint.
nonickatall
Germany
What is ATF/ blaster mixture?
ATF = Automatic transmission fluid?
Pb= Lead?
Blaster?
When I do Rost protection I remove the old loose rust and dirt, with a high pressure washer and then I remove the rust mechanically, but not with the needle rust remover, which is completely unsuitable in many places in the car, then I use rust converter to bind the rust.. Then I apply a suitable rust paint to the areas, if they are exposed to spray water accordingly to protect. After that I apply Fluid Film. I don't know if it's available in the US It's a sensational antirust stuff that's normally used for preserving ballast water tanks on seagoing vessels. After that i spray perma film from the same manufacturer on. That gives a hardened surface. this combination helps prevent new rust very good.
Hood hinges are ready. :)
MassHoe04
Western MA
Pb= Lead?
Blaster?
PB Blaster is a proprietary name brand of penetrating/lubricant spray.
nonickatall
Germany
PB Blaster ist eine geschützte Marke für Penetrations-/Schmiermittelsprays.
And that you mix with automatic transmission fluid? :oops:
MassHoe04
Western MA
Where are you hearing about mixing them? And for what? Context?
It was from @Walchit a few posts up...
nonickatall
Germany
@walchid wrote:
"I'm debating if I should paint over the rust kutter or just spray everything down with atf/pb blaster mixture so I the rust comes back it isn't under a layer of paint."
That's why I as a stupid German thinks. What are these great Americans which a able to lauch the James Webb Telescope, mix to protect a car from rust? ;)
And because I don't know any American brands for rust protection, I wondered what is a mixture of "atf" which I only know as "automatic transmission fluid" and this "Pb blaster", which I already thankfully learned from @MassHoe04 ... Thank you... :thumbsup:
Now I still wonder what he mean with ATF...
I have heard of spraying the undercarriage with ATF -yes that ATF- but never mixed with PB Blaster. That’s some chemists nightmare I think. :hmmm2:
nonickatall
Germany
Ich habe davon gehört, das Fahrwerk mit ATF zu besprühen - ja, das ATF - aber nie mit PB Blaster gemischt. Das ist ein Albtraum für Chemiker, denke ich. :hmmm2:
This is also a nightmare for the environment. ATF drips off and is washed off by spray water and ends up in the environment. A drop of oil contaminates 1000 liters of drinking water, they say.
I'm certainly not green, but you don't have to harm the environment through thoughtlessness either.
Keviebear86
A massive goose decided I wasn't done refinishing bodywork on my Tahoe and ended it's life taking a header into my passenger front door. Even tried to slow down and miss the damn thing...
Luckily I carry zero comprehensive on my insurance so I may get it fixed for nothing.
Maybe a good PDR guy can take care of it.
Got my hood back from paint and installed so I’m back in stealth mode with The Beast. Also tackled installing my new column shroud which turned into a pain but it’s done.
Scottydoggs
NJ
i got hit by a goose that was trying to take off. you know one goes they all go lol lucky it was my pick up truck and it hit the ladder rack, it moved the truck good. then fell in the bed dead. next block i pulled over and unloaded it.
nonickatall
Germany
if it had been fried all the way, I would think that the USA is the land of milk and honey. :Big Laugh:
Hodmjstone
