Low oil? ‘14 Tahoe 166k
Dustin Jackson
@iboughtatahoe23 Yes as long as it’s on the hash mark you’ll be fine. Ideally at the full end of the hash marks but your Tahoe isn’t going to catch on fire if it gets to the low end of the hash mark. Wipe the stick before you dip it to get a more clear reading. When you cannot see the dip stick through the oil is when you need to change it.
Rygrego
Mission Viejo, California
So do I top it off or just leave it till next change? And would a bad oil pressure switch cause a bad reading?
I would put your vehicle on level ground and try again. The entire end of the stick should be covered between the lower and upper marks. Pull the stick first, wipe it clean and reinsert for a fresh dip. Your picture makes the oil appear blotchy on the stick.
You’re looking at reflections. It’s good.
Super Moderator
Elev 5,280
Put it on level ground, let the oil drain down for 15-30 minutes, then check it. Pull the dipstick and wipe off the end, then reinsert and pull it out again. Read both sides of the dipstick.
ajdahl8660
