blueinkd
Niiiiiice… check those pushrods carefully.. lifter trays..? Cam retainer plate / seal..? You’re doing the oil pump.. might as well do a timing set.. cam position sensor..? Knock sensors & harness..? Sorry, I -like many on this forum- enjoy spending other people’s money..
I have all that new as well, was just too much to type. The knock sensors are oem Delco less than 6 months old, harness is new, cam sensor/oil press is oem same time I did knocks a while bCk. Was hoping that P0302 was a simple fix but here we are.=/
adventurenali92
Big Bear Lake, ca
Who can recommend a good product to cut & buff my roof, and probably going to need under these badges as well… :naughty: @adventurenali92 …?
Your porter cable and pads will work great. Check out P&S detail products by renny doyle. A little pricey but with every penny. He’s got a couple polish products I always have on hand for detail work. Run the smaller 5 inch pads on your rooter cable for the area up on the roof in-between the roof lines to get good results.
Sam Harris
Thank you! I already have some Chemical Guys VSS, I forgot about. Any thoughts on that?
MassHoe04
Western MA
Mileage OCD got a treat on the way home from work yesterday... This is my daily.
Walchit
Trying to wash 300k worth of grease and grime out of this thing, then gonna mess with this wire loom hopefully.
This picture makes me want to order a stall so bad.
Anyone heard any reviews on the BTR "Truck Yeah" converter? It's hard to find on Google and youtube.
mattbta
Frisco, TX
Yesterday picked up some mulch and stone for my dad with it. Didn’t realize he intended me to also install. :eek:
Assembled/loaded this grease gun I got after my thread here. Wow, the adapter and the loading mechanism are amazing. Hopefully no leaks.
Greased the rear sway and panhard. Will do the front this week when I get it in the air for an oil change.
Mudsport96
40.923,-89.488. Illinois
Nothing special, put the old 4114 bulbs back in the DRLs since one of the LEDs died. Apparently the Driver side drl/turn signal housing has a leak. Had a half inch of water in it that wasnt in there 2 days ago. We did have a few storms the last few days but damn. Well.... guess it is time for some fancy lenses.
Walchit
Looks like a good job.
Thanks! I started on the starter wire, and it has that fiberglass/aluminum tape at the end, so I spent way too much time reading reviews and not putting on the loom. I still haven't decided what to order for that.
Thought about just going over it with some aluminum duct tape, cause I have some on hand, idk
MassHoe04
Western MA
Tweakin' on another mileage OCD event!
Repeating number patterns... 21 21 21
Pay no attention to the P0455 behind the CEL curtain! We're old friends now...
You know its bad when you catch an alarming change on the cluster that makes you panic a bit. Then, you realize it was not any light that came on, but the orange CEL TURNING OFF!
Keep on truckin'!
Walchit
What products are you using? I’m liking that look.
The loom is "Gear It" brand from Amazon. I was having a hard time finding all of the sizes on there now for my neighbor, and I think maybe the "alextech" is the same stuff.
And "Tessa" brand wire loom tape.
It's a little more work than I anticipated, hopefully get some more knocked out today.
It's not very fun, lol
Oh yeah I know, I’ve done some. I have a bunch of different sizes of braided expandable stuff that I did some of the hoses with. Problem with that is you have to get the end connectors to go through it, then stretch it tight but it only expands/ contracts so much depending on the size so big end connectors don’t work. Yours didn’t look split in the pics, I’m thinking because you took some time and effort to make it look that nice. Good work. :happy107:
Drewphil
