Removing Rear Coil Springs
LoHoe
Mine been making that noise in the front end when i go over a bump or turn the wheel. not sure what its front yet. checked to make sure it was all torqued already.
NORCAL SS
SUV SUSPENSION GURU
have you disconnected rear shocks and tried if that was the issue?
NORCAL SS
SUV SUSPENSION GURU
yes like i said last week. Just unloosen off lower shock mount and let them hang freely and then jump on bumper see if stops. If it does then its the shocks or just 1 shock. Ive seen this many times before
YukonCrazy
YukonCrazy
Raleigh, NC
But jumping on the rear bumper now does not make the sound. I am guessing that maybe 2 sumo wrestlers jumping on the back bumper might do it. :)
Maybe I can make a temp speed bump in my driveway with wood blocls and drive over that.
houstontaylor
I know this is an old thread but, for the benefit of others, my 2003 Tahoe is making loud popping-like sounds in the rear during turns. Especially audible during sharp turns at low speed. I replaced the sway bar insulator bushings and links and it's still there. Put the Chassis Ears on the body mount bushing bolts - nothing. Putting Chassis Ears on the rear control arms revealed nothing. Just put the Chassis Ears on the rear coil springs and bingo! They are the source of the noise. Probably the spring isolators. I do have 330,000 miles and 20 years on it.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Let us know when you fix it and what was done, please.
ScottyBoy
Shreveport, La
Is it ONLY during turns? And is it not only a loud popping sound but you can FEEL the popping through out the truck as well? Because my 2001 did this when my rear diff went out. It was the spider gears stripping out on sharp turns, and it ONLY did it when turning.
If you are 100% sure it's the springs, then great. But its also possible the spider gears are stripped and the sound is possibly resonating through the rear end and into the springs. If you have not changed your rear diff oil in a while, I would drain it and go ahead and inspect the gears.
Geotrash
Dave
Richmond, VA
Excellent call.
For the driveshaft clunk, check the front differential mounts(2). The bushings go on it, and it starts to clunk. Purchase and replace the arms and bushings as complete units
ScottyBoy
Shreveport, La
Actually, if the driveshaft is clunking, that's another sign of a possible issue with the rear diff. I'd pull that diff cover and check it all out just to be sure. Get a good look at the spider gears and the pinion bearings.
houstontaylor
To update about the rear suspension popping or knocking noise, after replacing the springs with pads the sounds were still there. I put the chassis ears on the frame in the rear and found the sound in the rear frame everywhere I clipped them. I guess the sound was going from the frame into the springs and was not originating in the springs. The spring rubber pads, or isolators, were worn, hard, and cracked after 331,000 miles anyway so no wasted effort there. I did find some info on the internet about popping sounds in trucks with separate frames, as opposed to unibodies, when backing up while turning due to worn rubber body mounts. I just replaced all 12 body mounts and that was the source. I used the stock type rubber mounts. The rear two mounts were really loose due to worn rubber. Happy to have a quiet ride now.
NardDog
You just need big jack stands, the small ones wont give you enough height to be able to remove the springs. While youat it replace the OG shocks, theres a kit on Rock auto where you can get aftermarket springs and shocks so you dont have to get the expensive factory replacement.
NVMD looks like you fixed it
TejasPitt
