Removing Rear Coil Springs
YukonCrazy
Raleigh, NC
I have been trying to diagnose the noise coming from the rear of my 2008 Yukon for some time now. The noise occurs in the rear when driving over speed bumps or any uneven areas in the road. It sound like it may be the rear coil springs moving slightly, but that is just a guess. I would like to remove the springs and install new insulators on the top and bottom just to see if that is the problem. I wish I could mount a video camera under the car to capture what goes on over speed bumps.
Do I need a spring compressor in order to remove them?
Rangel
Great State of Texas
You can jack it up and let the axle hang. You have to jack up the axle and disconnect the sway bar links, shocks and brake like bracket. And I believe the diff vent tube. And the lower the axle down slowly. JUST WATCH FOR ANY LINES THAT MAY BECOME TIGHT.
Should have enough room to wiggle the spring out.
---------- Post added at 10:53 AM ---------- Previous post was at 10:51 AM ----------
What kind of noise? A clunk or squeak?
YukonCrazy
YukonCrazy
Raleigh, NC
It's more of a squeak like back and forth.
Rangel
Mine has the same thing. I inquired on here about it. Most seem to think its the sway bar bushings. I just have been to lazy to swap them. I'd try that first before dropped rear end.
YukonCrazy
YukonCrazy
Raleigh, NC
Those half moon shaped rubber bushings? I may replace those and the end links just to make sure.
RotaryMachineRx
Saskatoon, SK
Dropping the back end is simple as pie..... above poster was correct about watching for stretching lines and spring compressors are not needed. I recommend hopping over to the Belltech site and looking at their rear lowering spings... they have a link for PDF instructions to install them which outlines lowering the back axle with pictures and everything.... very straight forward.
YukonCrazy
YukonCrazy
Raleigh, NC
I guess my coil springs or good because after changing the sway bar bushings, the noise went away.
Now I am down to fixing the drive shaft *clunk*.
yates ™
Resident Apple hater
Iowa
Do you know anyone with a Go Pro? Those are perfect for situations like this.
Icyagent
