Part of the not cheating, not trying theory….Has anyone tried and either been successful or got caught………Submit orders from multiple dealers…no more than two………See which one comes in first? Knowing my luck they would both arrive on same time frame and be on the hook for both.
in 99% of cases when the dealer puts in the initial order it isn't actually being submitted to GM for acceptance since the dealer doesn't have a current allocation ...almost like this is what I "want" to order when they can place the order. would expect the dealer to contact the customer if it's been a month or two to confirm everything with the customer prior to pushing the acceptance button - if not, they should be
if GM changed their policies of where an order could only be submitted when it was immediately accepted (like other brands) I'd have a different opinion on the approach, but even then I wouldn't have any issue pursuing an order with two different dealers. Depends on what is discussed upfront if the vehicle isn't purchased by the ordering customer. Lot of rumors about how a dealer is impacted - some of which depends on how the dealer flags it in their system when they order it
we placed a Tahoe and Yukon order in Dec 21 at the same dealer (mid sized local dealer) and neither of those were ever built. (they didn't require a deposit)
Jan 22 we ordered from another dealer and took delivery on that order in late April (refundable deposit of $1k)
as far as deposits - just make sure to have that discussion when the deposit is made. A Ram dealer we ordered from required a $1k non-refundable deposit that i was able to just use a credit card for...months later i found out they were only accepting wire transfers for deposits because several "buyers" had contested the charge when they decided to not take the vehicle...the implemented this because Ram apparently "dings" the dealer when it's sold to someone not listed on the initial order.
place as many orders as you want - for all GM knows you are actually buying 5 vehicles. But I wouldn't go down that path if you or the dealer is going to be financially harmed - of course you won't be aware of their situation if they don't tell you the ramifications of backing out...so in that case, do what it takes to get a vehicle
