jdwood1111
- Joined
- Jun 16, 2022
- Posts
- 123
- Reaction score
- 148
Hi All,
I did not know if I should add onto a previous thread of mine or start a new one so feel free to merge if mods feel its necessary. Anyway, here is the quick summary that I need some diagnose guidance.
Stats:
2011, 6.2 XL Denali
Bought May 2022 with 92k miles (Range installed almost immediately)
Currently has 96k miles.
Dealer changed oil and trans cooler lines
VERY minor oil leak at the joint between motor trans observed just past dealer warranty. Could not really locate and nothing ever seemed wet I could tell from above. No oil pressure issues.
I added half a quart of ATF to the oil about 300 miles ago before changing the oil in which I used Valvoline full synthetic and a purolater boss filter with half a quart of lucas stabilizer. This was just before I just took the truck to a transmission shop to have the fluid and filter changed. Now after driving the truck (its a second vehicle) I figured I would check the oil leak and it definitely is worse than it was before! It has not dripped onto the driveway but looked like it was about to. Could the the ATF cleaned things out and the synthetic oil is making the leak/seals worse? Something the transmission shop did (how?)?
There still no visible oil I can see from above at all! There is nothing on the passenger side by the starter really. Where I do see the most is on the drivers side through the wheel well at the oil pan gasket and mostly above the oil cooler lines. I assume the gasket was changed by the dealer who changes the lines and it looks like more is above or at the pan gasket. I know there are a few things above there to check but wanted to confirm what and how. The valve cover gaskets do not seem to be leaking at all nor anything from around the VLOM that I can see. Oil pressure sending unit? Rear main I would not think would be on the side like that and inside the cover plate doesn't appear wet but I did not look this evening but will this weekend.
If it may be the ATF and new synthetic oil, is it worth trying lucas stop leak to see if I can undo anything or try locating something else?
Thanks in advance!
Stats:
2011, 6.2 XL Denali
Thanks in advance!
