Lean Burn Tuning?
donjetman
Lean Burn Tuning?
Anybody done this? I'm interested because we do a lot of hwy driving.
Here is 1 (of several) videos:
Just Fishing
Can't fix stupid
Utah
Corvettes already get pretty good gas mileage.
Heck my 84 can get 28mpg. :jester:
Still a neat idea, I have something called lean cruise in my aftermarket ecm.
I don't know how well it would work on one of our bricks. :jester:
Foggy
KS
Our heavy vehicles could never sustain speed with low of a spark airmass....
There is already some lean cruise stuff built in... Remember that that corvette is half
the weight and half the wind resistance...
And just to add: I wouldn't believe that DIC with aftermarket tune/injectors/cam MPG Reading
.. After mine C5 was tuned I was really happy with the MPG, except the reading was WAY off
as the fill ups at the gas pump showed (off by over 8 mpg).. Bone stock it was money accurate
donjetman
donjetman
I flew a twin turbocharged single engine aircraft that could be flown on the rich or lean side of peak egt. Range increased by about 20%, speed stayed the same, when cruised on the lean side.
If I lived anywhere near Chicago I'd have our Denali tuned like he did his C5.
Lean cruise was a feature of Gen III LS architecture and because of American emission standards was not used much, if at all, in the United States. AFM and VVT was the Gen IV answer to lean cruise. VVT alone is worth a solid mile per gallon in our trucks.
Foggy
KS
That's why I went with a VVT cam when I replaced the DOD stuff. It makes the tuning a little
more involved, but if I can keep my mpg at stock and still get the advantages of a bit larger
cam and NO DOD issues I felt it was a win. I'm still working on my tune, but so far I'm
at stock MPG without failure prone dod system
B-train
Lean cruise was common in the 90's on GM cars especially. If you've ever heard a 1993 lumina euro with the 3.1L you know what I'm taking about. Lean running, tuned properly, is a great way to increase MPG. Under stead-state you don't have to worry too much about detonation and the combustion is hot and clean. You can thank our idiots at the EPA for making this 'wrong.'
Lean running is hotter and more complete combustion which is more efficient (key word, efficient). When oil companies and tree huggers are in your pockets, you phase this out because it creates higher NOX. The new thinking is lower NOX which equates to higher CO and CO2, plus uses more fuel to do the same work because unburned fuel is used to keep the catalyst hot for post combustion.......if you follow the money, you see why emissions standards and mpg don't get along. There is SO much technology available in Newer vehicles (gas or diesel) to drastically improve efficiency.
But, tuning for optimum efficiency doesn't sell more oil......or DEF. It's funny all the talk about CO2 emissions, they exacerbated the problem all by themselves.
BTW you are correct about the dream meter being off after tuning. I always do the math instead.
Geotrash
Dave
Richmond, VA
Same, but mine is normally aspirated (C182 with the Continental O-470). I know we've chatted about flying before but for the benefit of others, lean burn primarily requires even air and fuel distribution between cylinders, and that's easy with our computer-controlled trucks. But even with my carbureted engine in my plane, I am able to get all cylinders on the lean side of peak EGT and have smooth, cool, high-power operation. It drops the peak internal cylinder pressures significantly as well so there is actually less heat going into the block and pistons.
I wouldn't hesitate for a second to run an LS engine lean at moderate power settings. The science of it is pretty compelling, with the original work around it dating back to the 1930s at Pratt & Whitney. All radial engine airplanes used to be run lean-of-peak back then because they wouldn't make their range targets otherwise.
I'll be interested to follow your experiences if you decide to try it.
Mechanic prepper
Lean Burn Tuning?
Yes I'm doing it now In a 2001 Silverado and 2002 suburban. Been working on it everytime I drive which isnt everyday...the pickup I'm over at 19 mpg tank average up from 15. I live in mountains and truck is always loaded with something..lol. Have to change platform to V and write entire..after that you can enable lean burn...
j91z28d1
I remember the 7730 ecm running $8D in the 90-92 camaro and firebirds had a complete lean burn written into the bin. just wasn't activated. story was told gm wrote it, it worked well but epa said nope it could damage the emissions system (cat) so it was clicked off.
once accessed it was a easy bit to flip and turn on. I've seen it in action. it worked flawlessly.. get up above the set rpm, and below the load point. it would go to 16:1 airfuel and like 60deg timing. Calc mpg would jump from 25 to 30. and once every 10 sec or so it would flip back to 14.7 to service the cat and check its math since it only had a narrow band o2 factory. I had a wide band installed so could watch it work. was seamless, couldn't feel a thing as it flipped back and forth.
that was such a good driving code for it's time. I just struggled horriblly tuning hot restarts with it, since it didn't use intake air temp but manifold temp plus time air spent in the intake. I moved on to a different code that was easier to tune, os from the sy/ty guys did a crazy amount of mods to but didn't have lean burn on it. always missed it. years later someone else went thru the bin file on a hex level and realized they had missed an inverse sign in the code making it even more difficult to tune the manifold air temp conversation correctly. always wished I still had the car and setup to retest it after that.
ahh the fun times following along with the smart people defining and hacking the obd1 ecm's. it's a shame nothing is being done with the newer gm stuff. just pay the company and take what you get.
a buddy is into the vw world. those guys are still doing wonderful things with the new cars. fully defined ecm, able to add patches to the code for new fiction and even have their bcm defined and mapped to make changes to how the abs and traction control works around corners. all lost in the democratic world of omg don't mod anything in the bcm or you'll kill us all. lol.
anyways... I don't believe lean cruise would do much for our trucks with the crazy bad aero. the engine load is to high at 70mph to run truly lean. you might get 15:1 out of it, but to run 16-17:1 on today's e10 87 octane crap fuel, you'd need very very low load, a lot of timing and maybe even egr which don't think anything since the first Gen ls1s in the late 90s had?
if you could patch these ecm's to run a wideband, you could probably tune it a bit leaner at like 30mph low load cruise around town.
Tune it for lean cruise and 91 or 93 then. Bet it would run even better.
B-train
Excellent writeup. Thank you for sharing that. There is a YouTube of a Chicago guy that tuned his LS1 corvette for lean burn using speed density tuning mode. He did a 100 mile road trip or so and calculated his results by hand - 40mpg I believe was his average.
I do agree that the trucks would be harder nowadays, but they do run so rich to keep the cats hot, that I'm sure there's room for improvement.
Case-in-point: I've been farting around with my beater 2008 Denali and have found that running mostly E-85 (50/50 to 70/30) blend with 87 fuel achieves me and octane of about 93-95. The 6.2L has higher compression, and absolutely LOVES it. More so than 93 non-ethanol fuel.
I occasionally get check engine lights for bank 1 and 2 running too lean. I'm good with this because it actually means it is leaner due to it not being calibrated for flex fuel. With the higher octane level, a light foot, and a scanner I can see the spark 45 -53 degrees BTC. Pretty neat and a programming computer would be fun to work with and tweak things.
Fuel economy with this is around 13.5 - 14.5 mixed driving. Used to be a about 14.5 - 16 on 87. The added power and pep is worth the decrease in mpg. Plus, it's cheaper than premium all around - mathed it out. Plus it smells good
donjetman
donjetman
See post#1 here in this thread for the yt video of the Chicago C5 vette.
I occasionally run a 20-30% premium/e85 mix in our non-flex fuel 07 6.2L Denali without issue. I drive conservatively, mostly hwy, and I'm getting 18+ mpg.
I hate the smell of e85. I was gonna run e85 in one of my drag cars but changed my mind when I found out how it stunk my shop up. I went with avgas instead. I like the smell of avgas and/or VP c-15 racing fuel.
B-train
That's cool. I did run a tank of premium no ethanol recently and the mileage wasn't impressive. I'm sure a tank or 2 more would've readjusted the fuel trims better. When I got to 1/4 tank I filled up with e85 (approx 75% blend). It ran awesome, but the check engine light came on.
If I run about a 50% blend with 87, no check engine lights and it runs well. I might try what you mentioned and see if anything improves. It's fun to experiment.
If I still worked at AVL POWETRAIN I could probably get my hands on some good tuning stuff. If I was independently wealthy, I'd hire a dyno cell and see what is really possible to achieve. The EPA really kills true engineering for efficiency. Plus, most of the population isn't mechanically inclined, so they have to tune for that variable. Which stinks
j91z28d1
what ecm is in that truck? have you looked into hptuners or efi live? you'd have to look it up, but some gm ecm's can pretty easily run ethanol sensor and have the tables already in them, just gotta add the sensor and enable it. yours might be one. if you have e85 local and drive often, it would pay for itself.
even if not, you can adjust for it some to not set codes. at least to the point you run out of injector. if you're going to play around with it without tuning, have something to keep an eye on short term and long term trims. as long as you're part throttle not in PE enrichment mode, your trims should add some fuel. been years but I believe even your narrow band o2's still target stoich for whatever fuel they see. they don't what it is.
I only run e85 thru mine stuff right now as a cleaner.. I've seen it clean up the top of pistons better than any cleaner. I'm with you, especially if you don't have cats. it smells much better. I've gotten so sick of smelling like gas fumes I've put cats back on everything. even my motorcycle. I swapped the exhaust on it years ago and tossed the stock with cat in the attic. few years back I put it back on.. was tired of the noise and the smell.
be careful if you find some av gas, most of it says low lead but its low lead for av gas. it's really high for the car world. if you do have cats, it's said to plug them up pretty quickly.
have guys with the 6.2 that wants 93 tried lowering the timing to run 87? wasn't a big deal when it was 30 cents more, but now it's a dollar more. kinda annoying if you don't drive it hard enough to notice a few extra hp.
even my ls3 c6 it's annoying to need 93 for highway trips, I was going to copy the low octane map into the high octane map and flash it for my next trip run 87 and then flash it back. when I got there. but I ended up trailering instead.
I was looking for a 6.2, kinda happy I found this 6.0 instead that seems perfectly happy daily and towing on 87.
j91z28d1
you're literally the first person I've ever heard say they didn't like the smell of e over gas.
what's c-15 up to these days? I haven't seen a race gas pump in years, since gas prices went nuts. used to be a 100 octane unleaded on the way out to the races. had a buddy check a few months back and it was long gone. turned into a non e pump showing 90 octain now.
man how times have changed
Mechanic prepper
I'm in the 20 percent better mpg at 17.9 to 18.4 to 1. About 50 degrees of timing ...zero detonation and trying to make a smooth primary ve table to cruise at about 40 percent throttle and 18.5 to 1 to reduce pumping losses. My injector duty cycle is definatley lower and I'm still running maf ... I will most likely switch to speed density soon to try it. But as I'm smoothing tables and waiting the couple weeks to payday to fill tank up for hand calculated results...I have 5 year average on this exact rig completely stock so have a good idea. I don't drive much anymore as I moved shop home but gas is near 5.00 again and I revisted this lean burn deal...it does Indeed work and lowers emissions across the board ....fun read is look at what honda did with the insight from 2001 to 2004ish....they ran a commanded afr of 22 -24:1. I have successfully ran the truck at 19 to 1 on my wideband but it tops out there so any afr has to be hand calculated by data logs.
My Ford Fairlane has a turbo 6.0 LS in it and I'm creating a lean burn boosted fuel map for it. I'm looking forward to see the increased efficiency of the turbo incorporated with lean burn. As soon as boost goes over 3 or 4 psi it will flip over to power enriched fuel tables and target 11 to 12.5 to 1 wherever the engine is happy and lower timing.
donjetman
donjetman
My race cars don't live in the trailer between races, they live in my shop. They are carbureted, so I have to live with the smell.IMO, the smell of 100LL avgas and C15 = Good, e85 and unleaded gasolines = Bad.
Last time I bought C15 it was $82 for a 5 gal can. Avgas is running about $5.50/gal here at our local country airports today. I ran 100LL avgas in my dragster instead of e85. I buy 100LL regularly and have for 40+ yrs. I run it in all my lawn care equipment and my ole 2 stroke golf cart. It starts lead fouling the lower spark plugs on my airplane engine (Lycombing o320/160hp) after about 30 hrs. Takes about 10 yrs on my lawncare engines.
See my avatar? That's my 1170 hp, 605 ci bbc, C15 burning Top Sportsman drag car. Used < 1/2 gal of C15 per run. Pictured below is my rear engine dragster (for our daughter) with 10to1 compression 572 ci bbc that I had planned to run on e85, but ran 100LL instead.
Our dragstrip closed so I sold everything and bought a bone stock low mileage 02 C5 Corvette coupe. I'm not gonna hot rod it.
briannorris
