10 speed trans question
pa31p
Waiting for an appointment (trans guy off sick) to check out the 10 speed shudder I’ve been seeing around 1200 RPM.
I crawled under the car just now to check for anything obvious, did not see any kinked/ leaking lines but did notice few things,
There’s two aluminum oil pipes coming out of the transmisson. both are cool/cold after an hour drive. The trans pan is warm/hot
The trans temp never goes above 120F after an hour drive. (32F outside)
the temps have me wonder if the transmission oil pump died, would this toss an error code?
Will post back, hopefully transmission tech back tomorrow.
Service advisor said there is no reported issues with 10 speed aside from few kinked lines, I believe him as you won’t find much info on problems with 10 speeds.
Mando6point2
I would think if trans pump died you would see alot more than just a shudder, complete loss of forward motion even. Trans codes would set too. Not sure what trans thermostat is set to on the 10 speeds but could be too low of a temp for it to open and send fluid through the lines and the cooler. how many miles?
Mando6point2
from brief research the thermostat on the 10 speeds opens up at 194 so that might explain why the lines are cold to the touch. Hope he can figure out the shudder issue for you i would think GM got that bug out of the 10 speeds but i guess not. Maybe a simple fluid flush with Mobil 1 fluid will do the trick like on the 8 speeds
StephenPT
St. Helens, OR
Driving in similar outside temps as you and mine seems to hold in the low 170's on interstate driving. Slower, in town driving I saw it climb as high as 185, but never above that.
pa31p
pa31p
Thanks for checking that, assume you have the 5.3L. hottest I’ve seen sofar is 150F even with outside temps around 65F
Dealer wants me to drive around as is for 1000 more miles, see if it disappears.
Fluid wise, this trans calls for the Dextron ULV atf fluid
wonder if it’s rebranded Mobil 1 blue label LV HP (used to fix issues in 8 speeds)
StephenPT
St. Helens, OR
3.0 Duramax
thegrunter
I'm new to this forum. I currently have a 2021 Blazer and the 9 Speed blew-up. They tried the fluid flush with 200 miles driven and that didn't work. Replaced the Torque Converter and that didn't work. They are now replacing the tranny. I suspect this type of problem would happen in the 10 Speed too and it appears it has. I'm thinking about upgrading to the Tahoe, but I'm afraid the 10 Speed is a lemon like the 8 Speed class action lawsuit going on now. It doesn't appear that it's an issue in this forum. Am I looking in the wrong forum topics to see if the 10 speed has more issues like the 8 speed did? Thanks in advance.
SpyShops212
ULV is specific for 10 speeds only. Do not use LV HP fluid on the 10 speed.
Vladimir2306
New automatic transmissions are really colder. My temperature in the city is 70 degrees Celsius. at outside 25 degrees. while past Tahoes showed under the same conditions 90-95 degrees Celsius
Mister421
Hi – Checking in to see if there was any solution to this problem.
We finally picked up our 23 Denali XL after ordering 10 months ago. Vehicle came with 3 miles on it and we still have under 100 right now. When slowly accelerating (like you would on an average suburban street) there is also a shudder coming out of 1st gear or maybe 2nd depending on how much throttle is given. It seems like its hunting for a gear and then jerks when it finds one. Not sure if we need to break this in further or we have an issue.
Thank you!
Mister421
Towmaster
