Charlie207
2nd startup for curing process.
Sounds good.2nd startup for curing process.
Can you explain the "piece of pipe" used to cancel the drone wavelength?
Since I'm not so much a fan of the size, shape, and angle of the exhaust tip that came with the kit, I'm just leaving it off until I find something more subtle, like a basic turn-down.
If a magnet sticks to the metal then it will rust. Gas grill makers get away with that misconception quite a bit.
There are many different grades of stainless steel and the word "stainless" can be misleading. I have a 1/2" thick book that I needed to read to spec the proper series material for a construction job near the coast.
Something you might want to look into is CRC Zinc-It. It is a cold galvanizing spray.
I wouldn't be upset.As an aside, after staring at a bunch of pictures and muffler cutaway images, I'm assuming that my $300 system is a knock-off of the MBRP $500 system.
Small update:
I had my truck up on a lift to be Fluid Film undercoated (mmmm.... sheep skin oil) and was curious to see how the primer & paint was holding up.
It seems to be doing well so far: no hot spots, bubbles, or rusty discolorations yet.
The 3" Kooks turndown I added to the tailpipe (the included tip looked gross, IMO) seems to have helped redirect the sound enough to lower the noise levels inside the cab slightly, which is nice.
They seem to be holding up well, and are doing all the things mudflaps do.How you liking the new flaps so far?
I had ap xcelerator turbo mufflers on my subaru forester.Good point.
I found the AP muffler you linked for $cheaper on Summit. https://www.summitracing.com/parts/aph-xs2579
I'm going to install the system as it is, and am priming/painting it now. My gf said she won't care if it's loud.
The JBA catback i had on my Armada was great quality, but pretty loud. This didn't bother me, but the drone at cruising speed was super annoying.
Would be about stock volume at idle but with a stronger rumble and with a louder bark at hard throttle: https://www.amazon.com/AP-Exhaust-Products-XS2579-Muffler/dp/B004A5OBVA
I actually just ordered this. It arrived yesterday, and some quick tape measuring has it at 28" OAL, so I'll have to cut 2" (1" on each side maybe) off of the existing pipes so this longer (26" OAL current muffler) one will fit.
I didn't mind the noise at all, but the rear seat occupants said it was droning enough that I'd rather quiet it down that make the kids lives unpleasant.
It's a still a straight-through muffler, so it should bark fine at WOT.
I rode in the back while the my GF drove around, up hills, fast, and all that, and it actually drones pretty bad. The resonance cancels out certain frequencies when you talk. I feel bad that the kids were back there getting their central nervous system rearranged.I never had any complaints with mine, even on 14+ hour road trips, back when I had the 18" body on mine. That 2579 has a 22" body, so it's like the Magnaflow version known to be "like stock, but with extra".
It weird how in the driver's seat it very minor, but just 3 feet back it's like being in a completely different vehicle. I wonder what sitting in the 3rd row would be like if I had a 3rd row seat.
