Reduced engine power without cel
travstick
Hello, new member, first post. Lokor help. I have a 2012 yukon denali 6.2. It's new to me so I don't know much about its past. The problem I have is with reduced engine power, some times when I start to pull out from a stop it will go into reduced engine power but it never has check engine light or had a code thrown. The check engine light works but doesn't come on when this happens. Anyone point me in the right direction to diagnose this. I have replaced the tps on the throttle body, just throwing money at it because that is what my Silverado needed few years ago.
wjburken
Eastern Iowa
Are you getting a Reduced Power message on the DIC or just noticing a reduction of power?
How has your transmission been acting for you? Condition of transmission fluid?
Do you have the ability of putting a scan tool on it and watch the live data to see what you can see?
Welcome to the Forum from NH.
Pics of the truck, please.
T
travstick
Yes, I get the message on the dic, transmission seems fine but it is me to me, and yes I've got a scan tool that will do live data
Super Moderator
Elev 5,280
Since the DIC shows the message, there should be a powertrain code.
CaptainAmerica1
Arlington TX
Check ltft against stft and report back. Mine did this when I developed a vacuum leak in my intake manifold.
BG1988
bad/ loose cable at gas peddle , throttle body controller actuator or loose cable at the throttle body
Stage2Tahoe
Stage2Tahoe
I just had the same problem with my 03 Tahoe. I replaced the TCM and the TPS and neither fixed the problem completely. I had to replace the throttle body. The drive motor for the throttle body was going bad causing the throttle blade to flutter at idle which caused rough idle and reduced engine power. I however got a code.
Goodlife_chevy
