14 bolt rear end swap?
Trey Hardy
Has anyone completed or done a 14 bolt rear end swap out of a Escalade or Denali? My buddy who’s got the parts Escalade said I could have the rear end out of it I just wanted to see if it was a direct swap or if I had to modify any brake lines mounting or u joints to make it work from what I Believe it should be a direct swap minus the u joints maybe? Thanks for any input cominging out a 10 Escalade going in a 07 tahoe
GMT800 2005 Tahoe Z71
Navy Supporting Member
Direct swap. Unbolt the old one disconnect brake lines and electrical connectors, slide in the Denali rear, reconnect. Should be an easy 2 hr job if the ratios are the same…
Great call and I believe @Dantheman1540 has a write up about it, if I remember right.
T
Trey Hardy
Thanks man I thought so Mine is fine I’m gunna gear and build this one to eventually swap in but wanted to jump on it since it’s a clean 100k mile rear end for only a couple hundred
I am wondering about something....I have brand new park brake assemblies and calipers and pads and lines and and and....on my rear diff. Does all that change over whe I would do the rear diff to a 14 bolt. I would think so but since we have a thread open and I have been curious for a while, I thought I would ask.
T
Trey Hardy
Wanting to run 4.10s front and rear with a locker and a nice differential cover & make some panhard bar spacers so I can run the mag hytec cover
Gunna rob the front differential too so I can rebuild it that way I can put everything in at once without down time of the vehicle.
Maybe @Dantheman1540 can chime in and answer my question.
Most of them are 6 lug so I would assume so as long as the calipers are the same size? I’ve only seen 2500 suburbans with the 8 lug wheels that’s why I’ve been shooting for the Denali and Escalade rear ends because I diddnt want to have to change out any axles or use wheels adapters
T
Trey Hardy
Randy did a write up about the swap too. @randeez
Make sure the donor Escalade or Denali is RWD or it will have the same 8.6 we're trying to replace. Most of the ones for sale on ebay are NOT AXNs even though they say they are. When you check the VINs you discover that those are AWD and were not equipped that way. I tried telling them years ago and was ignored.
The only thing different that I've been able to detect is that the brake lines going to the differential from the body are different part numbers. Still, I know guys that did not replace them and have not had an issue. I bought them.
U-Joints are the same so it bolts right up, no need to shorten the driveshaft either.
Is there an assortment of ratios on the 2wd AXN axles? I would just stick with my 3.42 gears. Snappy enough and decent on fuel mileage.
CaptainAmerica1
Arlington TX
Most of the ones I’ve seen from the denalis are 3:42. Only reason I have t done the swap is that I’m saving for 3:73 and the axn swap. Haven’t done a rear end since I was 17 so I’m gonna pay someone else to set it up.
I have never tried to set up a set of gears. I think I could do it but I know it is an art and just like electrical diagnostic specialists, if you find a good gear guy/girl, they are always in demand.
randeez
south florida
i believe all of the denali and escalade AXNs are 3.42s. there are allegedly some unicorn AXNs in avalanche/esky ext trucks that are 3.73/4.10s maybe ?
swap is direct, did mine in a couple hours at friends shop.
gear swap on them arent too bad. it was a little intimidating diy, but the process kind of ensures you get X set right before you move onto Y, before moving onto Z. if you cant get it within spec at any step you dont move on.
setting the pinion depth is no.1 - in my case the shims that came with the install kit i got put me too far or too close. so i used the smaller, but setting the backlash in spec resulted in poor tooth pattern. tried the larger, still couldnt get decent pattern when backlash was set to spec. ordered more shims, they took for fookin ever - i never checked the existing shim because i never took the bearing off the pinion gear but i ended up cutting the bearing off the old pinion to see what shim it had, and it was money. the 9.5(14 bolts in general) also has an adjuster on one side youre not messing with shims on each side of the caps, just one side.
now to preface all this - the few guys i talked to that knew gears told me : the first set up you should always,ALWAYS, set it up with whatever shims came out of it. because that is what it needs 9 times out of 10.
i didnt really document much cause i didnt really know what i was doing, wasnt sure if it would make it more than 5 miles, didnt want to put out bad info. i swapped 4.10s and a trutrac into mine....so far so good though!
I did run a shop once where I had a gear specialist and until you said it, I forgot that he said the same thing. Always start your gear set ups with the same shims that were already in the axle, in the same position packs.
randeez
south florida
yep. i figured since i was replacing carrier and all it wouldnt matter - cause no way the existing shims would be right (i was wrong).
i grabbed the "set-up" bearings from east coast gear supply, they are already bored out to slip on and off instead of ******* with the old ones and clearance them myself for $40 bux wasnt worth it. other reason was i dont have a press here (could have ran around and borrow friends but meh). to install bearings i just heated inner races up and the slid right on where ever (pinion and carrier)
the worse part is final installation of the pinion - you have the inner bearing with shim on the shaft already(its pressed on no problem there), it needs to go thru the housing, then crush sleeve, then the outer bearing (which has to be press fit on and bottomed out) or you cant put the yoke on and start the nut. and then you have to crush the sleeve to a specific ft lb while also checking the torque it takes to spin the yoke
My friend explained that the old/existing shims work, almost 99% of the time, because the same axle housing is used. If you have a different, used or new, housing, then the fun starts. He said, yes, every now and then there is enough difference in the gears and bearings that a different stack of shims is needed but the first response is always the original shim packs.
Dantheman1540
Sugar Loaf Mountain
Pretty much bolt it, possible U joint issue at-least when bolting to a GMT800. Any of the 99-14 rear brake setups with bolt right on, however you may have to change splash shields which required removing the axle shafts. Removing the shafts is cake with the axle on a table or stands.
4.10-4.56s and a trutrac would be my vote for a lifted truck.
Dantheman1540
Sugar Loaf Mountain
Here’s a link to my write up.
CKendrick
