Catalytic converter help...
AmunRoo
Chicago
So here's the back story. I was driving home on the expressway and suddenly start seeing the flashing check engine and I'm feeling misfires. I had my scan tool with me so I plugged it in and found out I'm misfiring on the entire Bank 2 cylinders. A couple days before I started hearing a sort of little rattle. It was like a raspy type of rattle. So I'm thinking it may be the catalytic converter on Bank two that took a dirt nap. Once I got home, I lifted the the truck and took some temperature measurements. At the back of the cat the temperature was almost 700 degrees, while the other cat was around 350-400. I also tapped it with a rubber mallet and heard some stuff rattling around. So the plan is to replace both of them I guess. My question here now is, what are the inlet outlet sizes? I'm trying to move over to a set of high flow cats.
As always, any and I'll help is greatly appreciated
BG1988
if one is 700°C (1300°F) it means you're dumping fuel into it, mine barely does 450°c (850°F) normally
Put a tape around it and measure or look up by application. I replaced my Y-Pipe and cats with Magnaflow. Cheap, Chicom cats don't last a year.
tom3
I think BG is on the target here. The converter is working, but being over worked I'm thinking.
Dustin Jackson
Could also be that dumping fuel and high heat into the cat is causing it to fail. Could be a chicken or egg situation, I would try to find the cause of the rich fuel mixture in that bank.
Would a failing cat cause the bank to be rich? Which problem is the cause here?
AmunRoo
AmunRoo
Chicago
So it turned out to be a bad catalytic converter. I ended up replacing them both with flowmaster high flow cats... She's running like a champ now!
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Holy crap how many miles you got on her?
AmunRoo
AmunRoo
Chicago
How did the coverter matrix not blow out of the tailpipe?
That is definitely a good question. I was wondering the same thing myself but I think that some stuff did make it down into the muffler. Either way, it's an excuse to buy a new muffler!
Meccanoble
Georgia
Just curious where and how much you pay for your cats? Doesnt the truck have 3 cats? 2 on the y pipes and 1 on the back of the same exhaust pipe?
Meccanoble
Georgia
The part number is 51578.
THANK YOU! I seen another that came up that is also compatible with our trucks. Much cheaper. Any reason I should go for the 51578? Here are details:
Model 51578
Magnaflow 51578 | CADILLAC ESCALADE, CHEVROLET AVALANCHE/SUBURBAN 1500/TAHOE/SILVERADO 1500, GMC SIERRA 1500/YUKON/YUKON XL 1500 | 4.8L/5.3L/6L.6,2L | Catalytic Converter-Direct Fit | OEM Grade EPA​
$1,070.30$1,013.00
or
Cadillac Escalade | Chevrolet Avalanche/Suburban 1500/Tahoe/Silverado 1500 | GMC Sierra 1500/Yukon/Yukon XL 1500 | 4.8L, 5.3L, 6L, 6.2L | 4WD | Catalytic Converter-Direct Fit | OEM Grade EPA​
$1,127.83$897.77
Towmaster
