RooTBeeRthe1st
What a cool truck!!
Chevy Luv. Can't remember the last time I've seen one of those.
My dad always liked them, so my first car was a baby blue 2wd '78. Drove that 3-4 years til i bought my old cobat ss sc. Then he got a white '80 for my little brother, then found a '79 4wd, sold the white one. I found a '79 4wd...turned out to be a parts truck. Sold it, dad found a 350 swapped '75 to turn into a drag truck(still in progress), sold the bably blue '78. Then I found my '80 4wd...not sure if there will be more in the future lol
That 350 swapped truck has to be a beast.
St. Louis
Doing the rearend oil, cover, and QA1 bar today. I dropped the spare and have the OE bar off, the lower sway bar links disconnected (for ease of access to differential), differential cover off and fluid drained. The fluid looked translucent like honey when it was draining. Did have an OE style gasket. Here's pics of inside cover and differential. Old bolts had red loctite on the threads, New bolts have lock washers but thinking of putting blue loctite on them
Sparksalot
Bastrop County, Texas
My grandpa had a Courier with a manual. I learned to driv on that at age 12. A couple of years later he replaced it with a Luv. Still with manual.
I didn’t drive an auto until I took driver’s Ed at 16.
You sure it was red loctite and not thread sealant? Because red loctite usually doesn’t give up without heat added.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Good stuff!! Did you drive up on the ramps? I didn't think they would clear under the running boards but I never tried that way myself.
Malik112099
Swapped out the headlights and fog lights today. Think it woke up my sleepy truck a bit.
St. Louis
Yup. Don't forget my front is lifted 2"
Before the lift i could only drive up forward on all 4 ramps.
I decided backwards today so I didn't have to deal with the ramps taking up space behind the rear tires where I was going to be rolling around on a creeper.
St. Louis
Finished, added about 2.5qts of fluid and all buttoned up and everything torqued to spec. That damn trackbar was a bit of a ***** to get the mounting holes lined up. It was very tight in the brackets. I did grease the bushings before trying. After a few cuss words and laying there contemplating the situation and what I had to work with I was able to use a big pry bar in certain locations to get it all lined up.
89Suburban
SE PA
Looks great man!!! Nice job!
YEP
Just got done looking at my passenger mirror motor. I pulled off the back cover and checked the wiring. When the fold button is pressed the mirror does nothing. No noise, no vibration, nothing. I pulled the plug going to the motor and connected a DVM to the 2 leads and set it to DC voltage. It was in auto mode and was reading very slight mV, but when I pressed the fold button the voltage would jump up into the 12v range for a second then go back down. So guessing it's a bad motor and not gear related.
I have to research what my options are here.
you could maybe find a used oem mirror on ebay a scratched up or damaged one and use it for parts
I think I used that same bolt kit. Looks great.
PG01
Up here to the right
Did the trans lines today, replaced the cooler too because why not…never and I mean never doing those lines again rotted right where GM put the little piece of plasticy wire loom crap to protect it from the diff or frame or whatever but it just made it rot out because of…. Northeast… (use your imagination) fell apart in my hands…. Cut that shit off the new line set…. What a pain in the d I c K … face full of rust and dirt …. Fun fun
Pic because….ya know
Glad to see you turn wrenches again Pete!
Charlie207
LFOD, New Hampshire
Is yours 4x4?
Did you have to remove the cross-member to get those trans-cooler lines out? I spent a couple hours trying to get the old ones out, but couldn't wiggle them free.
Also, got a face full of rusty dirt, or was it dirty rust?
Phlipnstik
