98 Yukon intake manifold gasket job - What do I need to know?
OilBurner2003
Hey guys, Question time. I have a 5.7 Vortec I need to do the intake manifold gaskets on, never done it before. On the left side of the picture is the valve cover, right side is my manifold. Leaking pretty hard too! I do think I need to reseal my oil pressure sending unit fitting, because it does look like some's coming from there, but there's three different spots on this manifold that I can see oil seeping out of, so it's got to be done, (Both valve cover gaskets are replaced.) I wouldn't have known really about this if some very friendly folks didn't help me out on this site.
The second image is my Oil pressure unit fitting, at first glance I thought it was Teflon tape that was hanging, but it looks like its RTV from the intake manifold. If I didn't have multiple spots away from this fitting, I'd just take it out along with the distributor and reseal it really well and test it throughout the days. Unless oil can travel upwards, Gaskets need to be redone.
Bottom line, is there really anything that is going to surprise me? Should I use RTV or the factory gasket that supposedly fits on the ends? Are there any tricks I'm supposed to know laying down the manifold on the surface when I reassemble? I'm quite confident I can rip this apart, (Famous last words) but I'm wondering if there's anything I might miss while I'm down there. I'm aware of the 1A Auto video that has a guide on this, how accurate it is though I'm not certain. Any and all advice is greatly appreciated, I'm just going to do research for now. Thanks guys!
exp500
Check spider bracket not bent,Use felpro gaskets, maybe a little more RTV than comes in tiny tube with kit, order the 10 mm upper intake studs and nuts, almost always overtorqued and stripped. Every chance you get, take pictures for you. When you think you are ready to install lower manifold, Double check everything, bolts in proper order, necessary tools ,everything organized,then clean it again where gaskets and sealant go. Wash hands, Rtv in corners, intake gaskets, RTV in corners again with front and rear squirt, then intake goes on.Torque intake then take break and plan next steps. Good Luck!
When lower is off, look at cam and lifters as best you can. Be very careful with injectors.
exp500
Look here also-
O
OilBurner2003
I very much appreciate this! I will probably look for more answers as I go, but thank you!
GMT800 2005 Tahoe Z71
Navy Supporting Member
Remember one very important thing, "Cleanliness is next to Godliness". **** and Span throughout the whole process. Check and double check. Measure twice and cut once. You do not want to go back in there from cutting corners.
O
OilBurner2003
Yup, I am planning to be as neat and tidy as I can. Thank you!
YukonGTmaster
2 Door w/ Barn Doors Club
This was one of my first posts on the forum when I was about to tackle the same job. Lots of great input from the nice people on here. Give it a read if you have time. I encountered a few speed bumps along the way. Good luck.
O
OilBurner2003
Just researching Which gasket set I might need, People are saying Use Fel-Pro, and some are saying don't. Which is weird, because I've never had a problem once with any Fel-Pro gasket.
In the shops I ran over many years, I liked Fel-Pro gaskets for cylinder head work on any engine and for the intakes. I sometimes used other brands because the tech that was doing the work liked a certain brand and they were the ones doing the work, so I would allow that. IMO, Fel-Pro is my go to but sometimes the OE Genuine GM brand or AC Delco will also do a quality job.
YukonGTmaster
Felpro is the one I used, and most of the people on the forum recommended. This kit even has new intake bolts with thread locker already applied. One thing I would do differently, is definitely clean and thread chase all holes you are bolting up to, to ensure proper torque.
O
OilBurner2003
Roger, Thank you! I'll probably make more posts about this job; I'm expecting to find more errors as I go, A very bad mechanic "rebuilt" this engine years ago. Your advice is very appreciated!
O
OilBurner2003
Thank you sir!
YukonGTmaster
Thank you sir!
I can’t remember what type of RTV sealant I used on the front and rear walls. Hopefully one of the members can chime in. Lay it on thick, and run it up to and under the edge of the corner of the new gaskets. Let it rest and skin over before bolting it down.
I can’t remember what type of RTV sealant I used on the front and rear walls. Hopefully one of the members can chime in. Lay it on thick, and run it up to and under the edge of the corner of the new gaskets. Let it rest and skin over before bolting it down.View attachment 378133
I like that RTV to be a bead laid on the outermost half of that flat metal surface you show in the pic. The reason is that when that is all bolted down and torqued, that RTV will spread front and back and if the bead is more toward that outer edge it has less chance of getting dropped in to the valley there and mixed with oil and then clogging the oil pickup tube screen. Again, only IMO.
east302
Mississippi
I believe most people use this? From what I've seen, at least.
The kit that Yukon posted has the RTV - enough for the two walls. They make two Felpro gaskets, one with internal metal reinforcement and one without which is the original GM style. The reinforced version (in that kit) is what you want.
The factory manual has the procedure with torques, bead size for RTV, etc. You’ll need that. You can download the shop manual here:
exp500
I did a quick search for upper intake stud/kit so I could post a link here. I found nothing. I remember a few different companies had them. GM/felpro/ others. Anyone remember a part number?
Escalade2007
