Question about the Headlights
nick14226
I’m frustrated for you guys.
Wonder what the dealers would say if someone with a ‘21 comes in and tells them they have a malfunction because only the drl’s are on in bright sunlight. Would they try to “correct”’ it so the headlights come on too?
From the '22 Yukon Owner's Manual:
Show that to your service advisor, and read it out loud if they have trouble with the GM wording. Clear as daylight to me.
SCiesie154
Moran Auto just cancelled my sensor order, said it was on back order from GM with no eta.
sanman28
Not sure why you guys let them control the narrative. Show them this pic and ask them when the vehicle is supposed to look like this.
GIIOST
Replaced the original 13545621 with the 13529378 last night (that does appear to have an older serial #) and I had headlights off and DRL's on the entire ride in this morning in the sun. Headlights were on in the garage as well as testing by putting hand over sensor. Also put flashlight on sensor and headlights went off. Form, fit, function seem to be the same, pin configuration matched, so this does seem to be a viable option.
Note, for the swap, I started with taking the dash panel off with some trim tools and some of the clips were really tight as I got closer to the windshield. Could envision something cracking or breaking a clip. I aborted that, put some painters tape on the dash right next to the sensor and pried it up with a small flat head screw driver. Popped up easily once I got under it and plenty of slack in the wiring to comfortably pull it out a bit to unclip the connector.
Original on the left, replacement on the right.
After 3 sensor replacements, I finally ordered the 2018 Camaro sensor and it worked. No more problems. It’s the same sensor ou recommended. Thanks.
972sparky
Well, at about 150 miles on the new premier, produced week of 6/20/22, I have the headlights on in the bright sunshine, cover the sensor and the DRL’s come on and the lights go out. Sound familiar to anyone? Will try the dealer next week first but not optimistic. Was hoping it was a batch in the March April time frame but looks like it goes thru June at least with the bad sensors.
BrokerThis
'22 Denali Dmax
Detroit
Produced week of 6/6, same issue. Just haven't had the time to go back to the dealer to have it addressed yet. I'm trying to take a good video/pictures of it prior to going in, just incase the vehicle decides it wants to act properly before getting serviced. But like you, I am not getting my hopes up of the dealer fixing it, and coming back with "everything is working fine"
LolaB
Update here. I just spoke to the dealership. They called me to follow up. Technician emailed GM directly. GM came back and said that it’s not a sensor part issue, it’s a software issue and GM is working on a update to the system that will take place reprogramming the sensor. GM is aware of numerous cases. They will advise once an update is available.
Follow up to the tape. I put the tape on the back half of the sensor all the way across it, works fine.
LolaB
Just took my 22 Denali to the dealership this weekend to replace the sensor I ordered on Memorial Day weekend. However, the issue was not fixed. My service advisor told me that GM released a service bulletin out for this issue August 3rd saying not to replace the sensor, but he did anyways because it was already ordered. Supposedly there is currently no fix either
Siems13
Mine is getting replaced today also. My sensor was ordered first part of June. Dealer didn't say anything about a service bulletin. I will report back on whether it works or not. I had been using electrical tape someone recommended in this forum, and it works most of the time. Guess if the new sensor doesn't solve the problem, I'll go back to using my electrical tape. So ridiculous to have these issues on such an expensive vehicle!
genestoy
Arizona
My 22 Yukon SLT was replaced back on April 20th and has been working perfect as it should since then.
LolaB
Right!?!?
972sparky
Stopped by the dealer today and asked the service manager t look into this issue. He looked it up and said there is a tsb issued 8/11/22 that is a reprogramming of the control module. Going to have it done during my 1st service when it comes due. No parts involved so no back order issues or batch numbers to worry about.
should have asked for the tsb number.
tuandan
Thank you so much for this. This was the perfect fix for mine. I don't know the build date for it but it was approximately around early or mid June. It is a Z71 Suburban.
I had to call at least 10 dealers/parts dept to get the 13529378. Got lucky and found one with a really really old SN. No one else had it nor could anyone else order the 13545621. I am in the Tampa Bay area in FL.
Hopefully GM will be able to resolve this for owners who are having the issue.
Lemondeanli2
Check my previous post. Probably on previous page. Tape mod is probably 80-85% efficient.
I’m at GMC dealership service Dept .
I came 2 days ago and they told me it works as it should : daytime headlights and running light automatically turn on and at night we have to manually turn on. I told them that is dumb and if it’s the case they didn’t think it through .
Well I’m back today same problem and guess what ? They have a GMC bulletin describing my complaint .
They told me it’s a software issue .
So we will see what BS they tell me today .
WalleyeMikeIII
Sunny and Snowy Minnesota
It is a software issue...and last I knew, there was no fix released yet.
nick14226
You're welcome! Just hang onto your original sensor. If there's a software update down the road, as the other guys have eluded to, that fixes the issue who knows if the old sensor will still work. So may need to swap your original back in :thumbsup:
tuandan
Yes, sir. Saw the comment on that too so holding on to the factory sensor
a1parrothead
