Stubborn Harmonic Balancer
P
Plimbob
Des Moines Iowa
Geotrash
Dave
Richmond, VA
A quick question, is there a specific pulley installer you guys would recommend? After some research, I was thinking this would work?
If there is another you guys have used which is better let me know.
Thanks,
Tim
That's very similar to the one I have and it works fine, except I don't have the ball bearing. I suspect it will get trashed the first time you use it, but se la vie. You can always sub in a hardened washer later for the next time you use it if needed.
Thanks,
Tim
For the harmonic balancer? You don’t need one, the harmonic balancer bolt does it. Keep in mind if you use an OEM one you need to use the old one to pull it in with and a new one to torque. I highly recommend an ARP bolt. You don’t need to follow the difficult torque steps the OEM one uses or the old bolt and it’s reusable.
Geotrash
Dave
Richmond, VA
When I installed mine, I could only get a few threads to catch before the bolt shoulder hit the balancer. I was worried that the force would strip them out. It might be a case of 'you might get lucky or you might not.' Since the installation tool is so cheap, I figured why not since the manual called for using the tool.
Just Fishing
Can't fix stupid
Utah
Just Fishing
Can't fix stupid
Utah
Thanks,
Tim
I use that same one to install, the little ball bearings like to come out, so I keep them greased to retain them.
I have never seen anyone use that to remove it, it should be a straight pull on some cast puller locations on the stock pully.
See above for the puller I use.
Actually I now remember I do use a long piece of allthread to start the balancer install, for the first 3/4” or so, then remove it and use the regular bolt. Not sure where I got it. Here’s my setup minus the Chrysler puller (OEM tools 27139, available at most parts store loan-a-tool). OEM bolt at the top, modified bolt for the puller to press against in the middle, install bolt at the bottom. The last balancer I did took 10 minutes off and on.
P
Plimbob
Des Moines Iowa
I have the balancer off. I was researching install tools to put it back on. I went ahead and ordered the one from Amazon I pasted the URL for. Seems the commonality is all of them have a long all threaded bolt, some use a bearing some don't and some have a head which to put a wrench on I suppose to assist in removal.
I decided to try the one with the bearings figured it would hurt and hopefully help the process. I see in the thread above -Just Fishing- had some issue with the bearings falling out. I'll keep an eye on that.
j_jerry79
