Got home safely yesterday evening and parked the camper in front of the house. Unhooked the hitch ball and went to shift into drive to pull away. Got as far as reverse and the shifter linkage on the transmission slipped off. Bushing failed. Terrible design, as many of you know. I'm barrel-chested so getting under there was a little uncomfortable, but I was able to get it shifted into park. I had a kit from bushingfix.com on hand because I knew it would eventually happen, but it's a POS so I ended up buying a Dorman clone of the original design. I think. Hard to tell which one is the correct one. Anyway, the original lasted 132K so I'll roll with it for now.
This is the one I got from Autozone's "help" section yesterday. Rock Auto says it's the right one, so we'll see.
Update: the bushing went on easy peasy. I let it sit in some hot water first to soften it and then installed it into the eye of the cable end first. I used a small screwdriver to make sure the whole lip of the bushing was through the eye and sitting properly in the groove. Then I used a pair of Channel-Locks to press the eye with the bushing onto the shaft of the shift lever on the transmission. Ran the shifter through its range of motion a few times and it seems solid.
More Information for DORMAN 14104
www.rockauto.com
