- Joined
- Jan 3, 2011
- Posts
- 50,911
- Reaction score
- 19,230
Go for itYeah that's the plan, lower the rear 2" to level it. On the cheap.
Maybe passenger side valve cover gasket. Might check the torque on the bolts first but be careful, they’re easy to over torque and snap. I forget the spec.Yeah I definitely want to lower it, not raise it. I hear that about the rear hatch, I'm 6'1 on bare feet. Miss my barn doors bad. I'm sick of climbing up into this all the time, so any changes at all will be on dropping it.
I parked in a spot at work that had a dip in it and went I went to get in it was SO nice to sit "down" into it for once. I'm gonna compare some measurements using that spot.
Any ideas where this oil is coming from? All over the starter area and leaking down. Hard to get good pics.
View attachment 371439View attachment 371440View attachment 371441View attachment 371442View attachment 371443
PPV rear springs and shocks ought to do the same.Thoughts on this kit?
HD Suspension 2" Lowering Drop Coils Spring Shock Ext Kit 07-20 Tahoe Escalade | eBay
HD Suspension 2" Lowering Rear Drop Coils Spring shock extender Kit for 2007-2020 Tahoe Escalade. HD Suspension Rear Lowering Springs and shock extenders. 2007-2020 Avalanche / Suburban / Yukon Xl / Escalade EXT.www.ebay.com
I would go with a known name like Belltech or similar myself.Thoughts on this kit?
Isn’t the oil pressure sensor on the driver side like the previous generation?It looks like it's been a slow leak for a long time. I'd say to clean it off and monitor for fresh oil. But, that pic showing it up high, behind the head and all over the top of the bell housing leads me to suspect VLOM or oil pressure sensor.
...Wasn't it you that found your VLOM bolts loose not long ago?
Yes Vlom, OP sending unit and screen, valve cover gaskets all replaced. I'm wondering if it is a weep from the damn right/rear steam vent seal. Mixing with a lower oil leak on the way down.
It’s 5.98 by me. Not gonna lie, dont even want to move herPut some gas in it.
19 gallons of E85 @ $4.19/gallon
Premium 93 octane was $5.08/gallon
***'n ridiculous
Are you sure the pump is leaking and not the adapter you bought? Did you buy the Motive adapter or something else to make it work? The pump just has a rubber flap on the bottom to seal, I don’t see how it would fail unless it’s deformed. In fact, I think it would only leak fluid out the top since that’s submerged in the new brake fluid that you put in the bleeder. You did put fluid in it, correct? It fills the MC automatically.Replacing rotors, pads and brake fluid this weekend. Opened the box for my brand new Motive pressure bleeder, only to discover the GM specific cap and hose were missing. After $30 in parts and two hours of driving/fiddling, it still won't hold pressure. The pump leaks internally. What a piece of junk. I guess I'm gonna teach my wife how to manually bleed brakes tomorrow. Meanwhile it looks like I parked in a bad neighborhood.
The adapter is homemade from a Dorman reservoir cap, some rubber gasket material, brass fittings, epoxy and hose. I can understand the skepticism. But I bench tested my thread seals successfully. I've only pressurized it with air, so far. I didn't want it leaking brake fluid everywhere. By the time I get Motive on the phone after the holiday, I hope to already have this done. So it'll be a quick conversation about getting a refund.Are you sure the pump is leaking and not the adapter you bought? Did you buy the Motive adapter or something else to make it work? The pump just has a rubber flap on the bottom to seal, I don’t see how it would fail unless it’s deformed. In fact, I think it would only leak fluid out the top since that’s submerged in the new brake fluid that you put in the bleeder. You did put fluid in it, correct? It fills the MC automatically.
