Radiator replacement
Sdp1234
Southeastern PA
Towing today with my 2004 Denali xl 6.0. Radiator is leaking bad. Had it towed home. A radiator replacement is now required when I return from camping. Should I go with an upgraded radiator while I’m at it? Recommendations?
Byoung1330
Cookeville tn
I would get a new transcooler while your at it. I been looking at getting one for mine. The true cool transcooler look to be very good. An since your towing it will definitely extend the life of your tranny
S
Sdp1234
Southeastern PA
Thanks guys. I have an aftermarket cooler but not the true cool. Thinking of bypassing the radiator with the trans cooler so I’m not adding the engine heat to the trans. Do the Denali’s have the oil running through the radiator?
bill1013
Air Force EMT/First Responder Firefighter
Waianae, Hawaii
If you've got the time & money I'd go with the completely metal radiator. The high impact plastic ones always crack along the seam.
I would not do that. In winter the fluid going into the radiator tanks helps bring up the temperature making it more efficient.
Would go stock or Mishimoto and there's another good one someone recently bought and liked... can't remember.
Sparksalot
Bastrop County, Texas
I bought a Coldcase all aluminum radiator for thecopcar. It looks like it’s a fit for the NBS Hoes as well.
SnowDrifter
Sasquatch Country
for what it's worth:
the trans passthrough for the radiator is on the 'cool side'
It basically provides thermal resistance. If it's cold, it'll add heat. If it's hot, it'll take heat away. helps to keep it in a narrower operating temp.
If you live somewhere that gets cold, bypassing this would be a bad idea. Trans will always run cold. PCM won't command torque converter lockup until the trans is over 75f. Cool is good. Cold is not.
I kept my radiator passthrough when I put the tru cool in it. Trans temps stay pretty narrowly in the 95-130 range, barring weather extremes (it was at like 140 when it was 115 degrees out)
S
Sdp1234
Southeastern PA
My radiator came in from Radiator Express. I expected it to be 1 1/16 thick but it is only 15/16. Called them to check and he said it is as good as the original based on ISO specs. I typically think details matter but he said they are required to be as good as original. Thoughts? Am I being too picky or is he blowing smoke?
Thanks
Thanks
it will work if you drive like a normal person and it doesn't get inherently hot where you live, if you tow often and in the summer it may not be the best option
the thing is radiators will fit 00-14, but nealry all are not marketed as such becuase of things like engine oil cooler or trans cooler options, etc
if you are not in a hurry poke around online, the mishimoto and cold case have already been mentioned but if those are too much money you can get a 1 1/8 from 1-800-radiator
just look it up as a 2012 yukon denali they run around $250 with lifetime warranty
I used to have a 2 row in my 00 but I don't remember what brand it was
if you find a good one and it says it fits anything (gmt800/gmt900) from 00-14 and it has the optional coolers needed then grab it, just be sure it is a 34" they do make smaller ones, if yours is not a 34" already and you do not have electric fans all you would need to change is the fan shroud.
MassHoe04
Western MA
Thanks for making a lower-budget recommendation! I may need it someday in the future.
S
Sdp1234
Southeastern PA
Next Problem...
I can't find the GM or AC Delco Tstat anywhere in stock. are there other brands (NAPA or others) that are safe or am I safer putting the old one in?
S
Sdp1234
Southeastern PA
I finished the project. Tstat and housing was readily available at the dealer. Didn't think of that because I typically refuse to get anything at a dealer.
If you are even considering this job... go for it, it's one of the easiest repairs.
I stuck with the radiator I was sold as the OEM replacement. They wrote me an email that promises to warranty return the unit toward an upgrade if I have any overheating issues over the next year.
I didn't really want to wait and also deal out the extra cash. Seemed fair to me.
Thanks everyone for your help
brice715
