04 tahoe - Any sway bars still available?
jeffg
I have been trying to order suspension parts for 3 days now... It seems like Eibach has discontinued almost all of the tahoe parts. Some front sways here and there, but no rears. They "might" make some in August if enough people back order them.
Hotchkis has discontinued all GMT800 tahoe parts.
So does anyone have a lead on a full set of sway bars that are actually in stock somewhere? Any brands still actively being produced?
1badjimmy
Not sure if you have checked them out but Summit Racing shows the Hellwig bars in stock. Quite spendy though.
Myfirstz71
Virginia
The Hellwigs are on the pricier side, but well worth it. I put a front one on my 07 after the stock mount rusted off the frame. Once repaired the Hellwig went on. Man did it tighten up the roll.
I’m looking to do both front and rear on my current 11 Z71.
hellwig makes them here in nor-cal
sd truck springs is there main distributor but you can get them from several places like amazon, summit, etc.
Hellwig sway bars are the way to go. As mentioned above, they are pricey, but well worth it.
1badjimmy
Well summit has 1 each less in stock because I talked the accountant into letting me have them ;)
BG1988
and this completely eliminates it
1badjimmy
Um hate to disagree but that is the predecesor of the magna ride or whatever GM calls is now.
Yet those vehicles equipped with it still have sway bars too.
Myfirstz71
Virginia
Lol……… what kind of $$$$ is that going to require. Of course while it looks and sounds good, I haven’t heard of anyone with it?
BG1988
yours can't jump though
J
jeffg
Out of no where, a big red eibach box showed up on my door step. 35mm front sway, lowering keys, hardware kit for front and rears sways, rear shock extensions. I will have to call tomorrow and see if the second half of the kit is also shipping. So weird, everyone told me eibach 3887.880 was discontinued.
Mudsport96
40.923,-89.488. Illinois
Let us know how it handles, im a cheap skate so next trip to the you pull im getting a 36mm from a 2500 Silverado if there are any and a rear from a one ton if available.
blueinkd
Energy suspension from sway bar bushings, energy suspension rear sway bar bushings and rear moog sway bar links and my truck drives and handles nicely 75+MPH. Sharp turns are controlled and the thing is just soo much nicer to drive on the highway. Granted I also have new shocks at all 4 corners. The energy suspension goods and moog links was less than $100 a few months back.
TejasPitt
