MDI for Park Assist, Side Detection, and Front Camera Service Messages?
digsub
I replaced the Side Detection sensor in passenger side rear bumper and Rear Bumper Harness that were damaged by heat above broken tail pipe in my 2016 Yukon SLT.
Park Assist, Side Detection, and Front Camera service messages persist on my DIC (even after I disconnected the battery for a bit).
Would this MDI clone or another method reset these codes? https://www.obdii365.com/wholesale/wifi-gm-mdi-2-diagnostic-tool-sp163-e.html
Any specific advice to avoid more $$$ hijinks greatly appreciated.
not completely sure but the sensor you replaced might need to be programmed, I'm thinking not but it's possible, it's also possible if the wiring melted enough it could have caused a short or blew a fuse, I would check every fuse to be sure, easy to do with a meter just touch the outer tabs with the probes. also double check any harness you plugged in to see if there are bent pins or bad connection
also the mid tool will show/reset codes & program, the catch is the software requirement, you can either try and get the hacked software or pay the subscription cost they have options, none are necessarily "cheap". programming would require a paid fee no matter what.
D
digsub
Woohoo... I checked fuses as suggested (thank you Doubeleive!) and found blown 28 (pic). Now I'm down to Side Detection Service message, which I suspect he's also right about, needs programming. Anyone know how to do this without a dealer?
Jacobhanke12
Woohoo... I checked fuses as suggested (thank you Doubeleive!) and found blown 28 (pic). Now I'm down to Side Detection Service message, which I suspect he's also right about, needs programming. Anyone know how to do this without a dealer?View attachment 368690
Which fuse box was this? The one on the side of the dash?
AaronIROCZ
Tomball Tx
EDIT: Whoops, didn't see that this post is 3 years old already.
Do not get the MDI clones, GM can detect them and will lock your AC Delco TDS account so you will be unable to use it or the account. You need a J2534 pass through device such as a TOPDON Rlink J2534 from Amazon. I have personally used this to relink my VATS when I replaced my ECM for my 10 speed swap on my 16 Silverado. You will also need a subscription to the AC Delco TDS system, you can get access for 2 years per vin for 45.00. Amazon link, https://www.amazon.com/TOPDON-RLink-Programmer-Reprogramming-Diagnostic/dp/B0DFM25BZB
scottd
