Tonyrodz's Tahoe Build Thread
Had to jump the battery today, which was strange. It only sat for 4 days. Battery is maybe 2 years old.
Been doing only short trips? If not it might be the alternator.
On another note- did you get snow from that last storm?
I used the Tech 2 and it showed it was charging. No short trips either, it's just been sitting. That's why it's strange.
Near me I barely got a scattered dusting. I'm in central Jersey, but up north they got 5-6". Gonna mostly be in the 60's this week, Thursday will be 70!
pwtr02ss
Tennessee
Warranty that battery
Got this code yesterday. Cleared it and it hasn't come back yet. Now I wonder if it is the battery slowly giving up the ghost. 20220315_131139.jpg
1 step forward. I finally installed the lower air dam.20220318_152622.jpg20220318_152700.jpg
At 1st just the abs light was on. It was the ds front sensor. Changed it out with a different sensor and now both lights are on. I tried clearing it with a regular scanner and it comes immediately back. I blew out a bunch of grease in the ds hub before putting the different abs sensor in. Everything appears plugged in correctly, and brake fluid level is fine.20220318_154552.jpg
I think I might've figured out why it's running like crap once it's "warmed up". It's been going on for a few months now. When it's cold it runs fine, and once driving it's running really rough. You can even hear it in the exhaust. I noticed the temp gauge doesn't go past 160, even if it's been driven for awhile. I'm thinking the thermostat is staying open, not allowing it to go into closed loop--just a theory. I haven't been able to confirm the temp with the tech 2, but I'm pretty sure that's what's going on.
Opinions?
So now the temp gauge appears to be working all of the sudden, not sure if it's fully working tho, but still running like garbage. Almost sounds like a miss.
Gf said it was throwing off alot of heat too, just radiating heat. Felt like the heat was on, but it wasn't. Gauge shot to 210, then went back to what the pic is showing, and stayed there. Opinions--temp sensor? Thermostat? I haven't been able to put a scanner on it yet.
brice715
