2004 6.0 NV4500 Tahoe
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Making progress slowly on the tune, cleaning my MAF and MAP seemed to help a ton. Also I finally got fed up with the catch cans not catching all the vented oil so I'm running the can with a breather to vent to atmosphere instead of recirculating into the intake. The main reason for the change was that the MAP sensor was soaked in oil, also since the can was reentering the intake behind the MAP and MAF I figured it might be causing some vacuum leak symptoms. The truck hasn't stalled since the cleaning and replumbing.
Anyone have a wood grain steering wheel for sale? My leather wrapped one is starting to peal at the top and it drives me nuts. I hate steering wheel covers, and have always liked the escalade wheel feel. Not overly concerned about the fact I have no other wood trim anywhere.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Actually managed to find a wheel on flebay so it should be here in a week or so.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
hows the welding coming?
Metals getting stuck together, I'm pretty competent to weld just about anything steal or aluminum. Its more of the fab side of stuff that I wish we would get into more. I might pull the Tahoe exhaust off soon and clean up all the welds with some Tig action. I know everywhere I goobered mig welds on is pretty ugly and I think I have a few small pin hole leaks.
randeez
south florida
im about ready to throw my pos mig in the trash, i can lay down some ok looking welds..but the thing is so inconsistant with feed speed, or even feeding at all and amperage. like literally the same thing i was just welding 10 minutes before the welds turn out completely different. i nearly ordered the same everlast you got the other day...but i really dont have much to weld atm so i didnt
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Make sure the lead is not kinked and doesn't have any sharp loops in it, it can really mess with how it feeds. Migs, even really nice ones can be super annoying. I probably had to stop every 2 foot of weld to clean the nozzle on the big millers we have at school just because of how much spatter it put out.
That Everlast has worked great for stick welding but I have yet to TIG with it, I really need more power to my shop and I have basically everything but the conduit and the trench dug.
TIG is life, TIG is love.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Is yours a scratch start or do you have a pedal.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I’m currently working scratch start carbon steel in my class, I’ve already don’t pedal start aluminum and SS. My Everlast at home has the ability to be scratch, pedal, or what I guess I’ll call a “dimmer switch” on the torch itself. Basically a hand pedal on the torch for out of position welding. I can’t wait to use it for TIG but it’s so much easier to take stuff with me during the week and use free supplies for now.
Scratch start feels like poor people TIG, pedals are cheap and I don’t ever want to do weird structural stuff. Worst case scenario if I’m laying under a truck trying to TIG I can set the max amps to what I want to run at and just use the pedal as an on/off switch instead of a throttle if that makes sense.
I feel like I've already asked, but have you changed the liner?
George B
¯\_(ツ)_/¯
I learned on stick so scratch start is hard for me. I stick it like I am starting a stick welder.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I didn’t even know liners were replaceable.
Yeah it’s not fun to stick your tungsten and have it burn half an inch off it. Really not fun to forget to turn your gas on.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Can't remember what is considered safe IDC but I'm at 90% at 6k but 11.5afr so once its leaned out I don't think I'll be any higher that 90% even at 6,500rpm.
Still having that weird ass rich condition that shows up in the first minute of driving. as well as the AC compressor not always wanting to stay on. I need to put a set of gauges on it still but I don 't think its a pressure issue, Fairly convinced its a tune issue.
randeez
south florida
tuning sucks
yea 90% is ok every once and a while at the top of a pull - you on e85?
my ac is still assfucking me too. idle is dead nuts on without ac on, with ac on and compressor always pulled in stable all day too. soon as compressor starts cycling it all goes to shit rpm swings from 400-1200.
whomever is responsible for censoring words is slacking
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
tuning sucks
Yep that's exactly what symptoms I'm having. I tried adding stuff to the engine>torque model>loss> AC compressor vs pressure table before I did these heads but I was having a little bit of high idling so I just zerod it out and I'm about to try it without it. I have a feeling its gonna be worse and then I'll end up adding more than before. assfucking assfucking assfucking assfucking assfucking.
Wow your totally right someone ain't worth a ****.
randeez
south florida
yea ive tried adding to the torque loss tables n crap, more and less, the gen4 crap has like a fade in/out of the torque ive tried moving those all over and it just gets worse.
i havent tried to completely remove it all which i guess i probably should to just see if its not needed
tuning sucks
Ass
Shit
*EDIT*
Nope. **** and loín are still dirty. Nanny Bot still on the job.
6point2lovelifers
