Walchit
Well, what ARE you doing? Full rebuild? New bearings, rings and hone?
I was trying to avoid the machine shop and just toss all new bearings and seals in. I bought rings and the tool to gap them.
I also bought a digital caliper and some plastigauge. I'm kinda worried about the cam bearings fitting tight now that one was spun.
Ps. I'm gonna have to Google scope creep
Walchit
This is what's happening, I I hope it's not harmful, lol
I tried to pull the cam out while the lifters we're still in there, with the engine upside down, and it was binding up. After I puller the lifters out with pliers and probably destroyed a few, the cam was still not wanting to come out. Found the problem afterwards.
Extra wide cam bearing... Lol
I bet that motor had a tick. That's what happened to my 1st motor too.
It had 3 broken exhaust bolts so maybe they couldn't hear it over that, lol.
I just found some slag under the thrust bearing too.
Gonna take the block to the machine shop? At least for a hone and clean up?20200702_100248.jpg20200702_100240.jpg20200702_124329.jpg
My motor with the spun cam bearing. There wasn't a lot of mileage on this cam, less then 20k. It was a BTR stage 3 truck cam.
Walchit
Gonna take the block to the machine shop? At least for a hone and clean up?View attachment 365248View attachment 365249View attachment 365250
I thought about making my own hot tank, I might call a machine shop,but the only ones I know of are kinda shady so I need to do some research.
I was gonna ask what cam you were running. I am leaning towards the btr torq cam, but I really want that Truck Norris, lol
I'd just go around the water heater. Wouldn't that be a pita to move?
Nah. It took me about 20 minutes to install a new one once the water was drained. Disconnect power and two water lines at the unions. Grab the hand truck and away it goes. The washer and dryer are harder because they’re bigger.
Drewphil
