PPV front strut replacement part
olliec420
So I have 09 XFE Yukon. It is dropped and inch or so like the PPVs are from the factory for “fuel economy” and stability. What is the proper correct length replacement strut for your PPVs?
olliec420
olliec420
Post the last 8 digits of your VIN, and @915_Tahoe may be able to give you the exact replacement part numbers.
Ohh ok great, thanks for the info. The shop says they got the right ones now. Hopefully they’re right, if not I’ll reach out to him for sure.
olliec420
olliec420
Hi @915_Tahoe, could you please give me the part numbers for replacement front struts and rear shocks for my 09 XFE Yukon last 8 = 9R218071. Thank you!
olliec420
olliec420
I'll get you that info first thing g in the morning.
Hi 915, I don’t mean to pushy but I need those numbers and to get them on order So as I can install before the end of next week for a trip. I appreciate your help and anything you can do to drop me those on Monday. Thank you, brother!
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
Frnt absorber LH/RH
GM# 20765171
REAR ABSORBER LH/RH
GM# 20833776
Discontinued
olliec420
olliec420
Frnt absorber LH/RH
GM# 20765171
REAR ABSORBER LH/RH
GM# 20833776
Discontinued
Thank you! Rear discontinued... I’m assuming I can find an aftermarket with the same length by searching that part number? Sorry for all the question, I’m new to older trucks.
915_Tahoe
HELL PASO, TX
You should find something the same by referencing that gm#
iasylum
