PPV front strut replacement part
olliec420
So I have 09 XFE Yukon. It is dropped and inch or so like the PPVs are from the factory for “fuel economy” and stability. What is the proper correct length replacement strut for your PPVs?
olliec420
olliec420
Post the last 8 digits of your VIN, and @915_Tahoe may be able to give you the exact replacement part numbers.
Ohh ok great, thanks for the info. The shop says they got the right ones now. Hopefully they’re right, if not I’ll reach out to him for sure.
olliec420
olliec420
Hi @915_Tahoe, could you please give me the part numbers for replacement front struts and rear shocks for my 09 XFE Yukon last 8 = 9R218071. Thank you!
olliec420
olliec420
I'll get you that info first thing g in the morning.
Hi 915, I don’t mean to pushy but I need those numbers and to get them on order So as I can install before the end of next week for a trip. I appreciate your help and anything you can do to drop me those on Monday. Thank you, brother!
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
Frnt absorber LH/RH
GM# 20765171
REAR ABSORBER LH/RH
GM# 20833776
Discontinued
olliec420
olliec420
Frnt absorber LH/RH
GM# 20765171
REAR ABSORBER LH/RH
GM# 20833776
Discontinued
Thank you! Rear discontinued... I’m assuming I can find an aftermarket with the same length by searching that part number? Sorry for all the question, I’m new to older trucks.
915_Tahoe
HELL PASO, TX
You should find something the same by referencing that gm#
balln2k11
Any shock/strut from a civilian tahoe/Yukon (non-auto ride) is the same as a PPV. The PPVs come with a Monroe PPV specialty shock/strut. They are extremely firm.
The PPVs get their ride height from lowered springs. I would go with the Belltech ProStreet for front and rear. The fronts allow you to drop up to 1” if needed. Rear springs on a PPV ride on a 2” drop spring, but they ride horrible. Any 2” lower spring gives the same PPV height but with better ride comfort.
olliec420
olliec420
Hey 915, I replaced them rear shocks and the ass end is still “squatted” a bit. Now I’m thinking it’s the rear springs. Can you provide me the part # for my xfe 9R218071? Please and thank you!
Escalade2007
