Just Fishing
Can't fix stupid
Utah
You can have it for the price of shipping. I'll be traveling for the next 10 days but will box it up and send it out when I get back. PM me your address and preferred shipping method, and I'll let you know the shipping cost.
Nice!!
And what derale did you get?
The more i look at their stuff, the more i love the company.
I have a derale cooler that's not really meant for transmission fluid, but it's very low restriction.
I decided I'm going to try it on the hoe.
They also have units with built in fans, seems to be very good quality.
Geotrash
Dave
Richmond, VA
Nice!!
I have the Derale 13960 in my 2012 XL Denali, mounted behind the lower grille which I ventilated carefully to allow airflow to the cooler.
Just Fishing
Can't fix stupid
Utah
That looks like a nice one.
Those derale coolers could in theory, be mounted anywhere.
Last night i started measuring the current fluid cooler, and started preparing the new tubing.
I noticed i have enough tubing to relocate the cooler to the back of the hoemare if i wanted.
Of course, that would probably get packed with mud and sage brush... lol
Yeah, it's big enough to block airflow through the radiator to the point that it causes engine cooling problems if towing heavy in anything above about 70ºF ambient temps. At least when there's a 6.2 behind it anyway.
Especially considering there’s also an AC condenser between that and the radiator. I have an intercooler too which is bigger than that TruCool, and I installed their next size down in a lower location behind the bumper. There’s only so much you can cool down.
Amaster
Laramie wyoming
What do guys think of the titanium heated seat door pull in place of the black ones I like them gives the door panels more ancient
Did you paint them or are they OEM? Need the filler piece before making judgment.
CaptainAmerica1
Arlington TX
Whats it look like where you hooked it to the radiator cooler?
Glenn’s Auto Performance recommended bypassing the radiator completely, so it’s just straight back to the transmission. The kit was pricey but I had it installed in about 40 minutes and I’ve had zero leaks since installation.
pwtr02ss
Tennessee
I want to keep the stock cooler.
Most of my engine parts came from that guy. My brother is/was a dealer or something for him.
Thanks to the kindness of @Geotrash I'm digging in on how the best way to go about installing it since mine didn't come with the external cooler and I replaced the lines with new GM when I had the engine and trans out.
Just Fishing
Can't fix stupid
Utah
I was just tinkering with my OEM transmission cooler lines.
a -6an tube nut and sleeve was a perfect fit.
A little hard to flare, I had to really crank down the 37 degree flaring tool
I might suggest stainless or steel sleeves and nuts in order to get a good clamp on the flare.
I just had this up, I was thinking ideas about how I'm going to route my cooling.
Now I'm thinking I'll split the fluid at the line filter.
then run one end straight to the external cooler, and have a valve to control flow (winter).
Then for the radiator side, retain mostly stock...
then that turned into "maybe keep some of my original lines" etc.
:yaoface2:
if you want keep it running thru the radiator then you just need 1 extra line and then the adapters needed.
1. enters the radiator from transmission
1. exit's the radiator and flows to external cooler
1. exits the external cooler and returns to transmission
or it could be reverse, either way you just need 1 extra line.
Drwinlied
You’re welcome. I’m always happy to help people spend money. :cool: But I was right, huh? It’s almost a joy to bleed brakes with one.
If I'm honest, nothing is fun in regards to to under the car on a lowered vehicle haha. But damn if this ain't the best thing since sliced bread. a huge thanks, again.
Hey, I want to join in on the Tru cool 40k kids club! Mine has been installed in this location for 2 years!
So both Powerstop and the vendor I bought from need a few days to look into if they can get me a proper replacement or not on the caliper. U know, items can't be returned or exchanged if they are used...(anger).
To add to this $hit sundae, when doing the front brakes I noticed the cv boot had a hole in it and ALL the grease was out. There's another $400, because f doing that myself.
Axles aren't that hard to do yourself. Save yourself some money and do them in your driveway.
Sorry about your issues with the Powerstop stuff. That sucks :(
Geotrash
Dave
Richmond, VA
I can tell y'all first-hand that you DO want the radiator's fluid cooler IN the circuit BEFORE the external cooler. I've run it with and without and the temps were out of control without it in the circuit when towing over the mountains in the summer. The water-to-oil cooler in the radiator does a great job of warming the fluid when it's cold and taking the heat out of it when it's hot. The GM upfitters manual also makes the same recommendation.
pwtr02ss
Tennessee
Like Jacob said, those front axles are pretty easy. I think I had to take the strut off and then the bolts holding the axle on. I cheaped out and bought them from advance auto instead of the gm units. From what I could tell, basically all aftermarket axles are the same and with the parts store house brand, lifetime warranty and I don't have to deal with shipping and wait times if I have an issue. I did both sides in an afternoon
varminpoolteam
