Dantheman1540
I did not thoroughly clean the heads from the machine shop because they came in a vacuum seal bags and appeared to be spotless when I unpacked them. Is it possible that they were full of CNC shavings?
Valve seal springs…Also it’s kinda hard to tell in the pictures but it almost looks like the metal is little teeny tiny pieces of spring or possibly shavings as if someone was drilling into some thing and left the bits
You’re a genius you’re right! How in the heck did that happen? All they do is sit down on the little lip in the valveValve seal springs…
It isn’t too hard to get the springs to pop out of energized seals. Do the valve springs rub on the seals?You’re a genius you’re right! How in the heck did that happen? All they do is sit down on the little lip in the valve
They did not seem to when I installed them but it’s almost impossible to tell now the spring blocks my view.It isn’t too hard to get the springs to pop out of energized seals. Do the valve springs rub on the seals?
They are separate springs and seats and looked exactly like what was on the 862s, the seats are from comp and the seals are from BTR. I genuinely didn’t realize there were some for dual spring and some not for duals I just looked at what I pulled off the 862s and compared to pictures on Amazon who was the only one able to get me stuff within the week.You should have received different seats that came with the springs, then the style seals I showed you. The seats and seals are 2 piece instead of the 1-piece seat and seal. I know when I bought my springs from VHP, Roger made sure I had the seats and seals that worked with them and told me the reason. Where did you buy your springs from?
Which ones did you install? The inner spring will hit on the step you can see on the hat style which would make noise I believe. I forgot, yes the seats are a separate item regardless but you need the seals on the right. The factory style seals like the ones on the left have a step that causes interference with the inside of the inner springs. You probably have a bunch of hammered seals if you used those. You can also tap the seals down too far and damage them which you might have done if they’re the ones on the right that are in there.They are separate springs and seats and looked exactly like what was on the 862s, the seats are from comp and the seals are from BTR. I genuinely didn’t realize there were some for dual spring and some not for duals I just looked at what I pulled off the 862s and compared to pictures on Amazon who was the only one able to get me stuff within the week.
This is what I used. Not sure if this would have caused the noise I was hearing on the passenger side tho.
Call me double stupid but I installed both, the larger hat style first then the smaller ones on top. They fit beautifullyWhich ones did you install? The inner spring will hit on the step you can see on the hat style which would make noise I believe. I forgot, yes the seats are a separate item regardless but you need the seals on the right. The factory style seals like the ones on the left have a step that causes interference with the inside of the inner springs. You probably have a bunch of hammered seals if you used those. You can also tap the seals down too far and damage them which you might have done if they’re the ones on the right that are in there.
New plan is to run these since they are designed for the exact TSP springs I have and should make instalation even easier and fool proof.
Precision Race Components Integrated Valve Spring Seat and Seal for Dual Valve Springs - Set of 16
Precision Race Components Integrated Valve Spring Seat and Seal for Dual Valve Springs - Set of 16www.texas-speed.com
I wish youd have let me practice on you first!id let you seal my stem any day of the week![]()
So much fun doing things twicePretty cool that you're "springing" for new seals.![]()
I think you might have found the source of that noise.Call me double stupid but I installed both, the larger hat style first then the smaller ones on top. They fit beautifully![]()
And you probably got away cheap. Most times lessons like this are expensive.![]()
wait what? you double sealed them?Call me double stupid but I installed both, the larger hat style first then the smaller ones on top. They fit beautifully![]()
