- Joined
- Jan 3, 2011
- Posts
- 50,973
- Reaction score
- 19,509
Gave her a fresh oil change with full synthetic and an K&N HP-2011. Ready to go until the next time
Gave her a fresh oil change with full synthetic and an K&N HP-2011. Ready to go until the next time![]()
I wish "they" were all as observant.Yeah - She has learned to pay attention to them over the years which is very helpful since I hardly ever drive her vehicles. She does a good job of pointing things out when it's not what she is used to feeling or hearing.
I based the tank size on looking at pics others have previously posted.
For fans and shroud, it was replaced by recall 2 years ago. It does have a top and bottom lip.
View attachment 363430View attachment 363431View attachment 363432
Thermal expansion joint. There are a few on it. There was an explanation in the box.I was looking at this and thinking wth happened?!
But I just looked at mine, same cut.
weird!!
Maybe that prevents warpage when they weld this thing together?![]()
Who reads instructions, duhThermal expansion joint. There are a few on it. There was an explanation in the box.
RTFM just confuses people. Donchaknow.Who reads instructions, duh
i figured what it was initially. There are times my degree in train driving comes in handy.Yeah, i apparently didn't read anything.
I noticed a warranty card and a sticker!
I'm still holding onto the foam packaging, but the box was made into future laying under the hoe sheets.
She's only got 64,000 miles on her. Her diff fluid should be so fresh you could drink itCheck your diff fluid, mine just took a dump.
turbos?Noticed a whirling sound on the Avalanche. Sounds like maybe the AC compressor? Its around 1200-1500 RPM and then either the engine noise drains it out or it goes away. I'll need to do some more investigating when it warms up.
Sadly, noturbos?
While replacing my water pump and radiator last week I just happened to spin the tensioner while I had it in my hand…..glad I did. Sounded so dry and rough I bet it would have failed in a few thousand miles. Easy to check!!Noticed a whirling sound on the Avalanche. Sounds like maybe the AC compressor? Its around 1200-1500 RPM and then either the engine noise drowns it out or it goes away. I'll need to do some more investigating when it warms up.
Everything on the front of the engine is new OEM, Gm stuff. Everything was replaced 6k miles ago while I had the engine out. It could be a tensioner but it sounds like it's on the passenger sideWhile replacing my water pump and radiator last week I just happened to spin the tensioner while I had it in my hand…..glad I did. Sounded so dry and rough I bet it would have failed in a few thousand miles. Easy to check!!
Thinking that it's on maybe?LOL, wth is wrong with a TV screen that it can kill the rear speakers?
