Useless Information
After some hard running in the dirt, the Sierra's original tie rods were now worn out. They started wearing down the front tires across the tread, less on the inside and more on the outside.
We installed new OE inner and outer tie rods and had a problem, the new ones could not be made as short as the ones we took off! Huh? Turns out, they both needed to be cut down 1/2" according to the Zone 6.5 Lift instructions. Ohh yeah, now I remember reading that! So we did that and still came up about a 1/16 to 1/8 inch too long.
We left it as is because new tires were on order and we had an appointment at the custom truck shop for installation and an alignment coming up. In that time, the tires wore down evenly rather quickly, so by the time they were replaced, they wore down evenly!
Truck shop called and said the tie rods were no good and wanted to start over and use Moog or some brand called Precision. We said no. Sent them the Zone instructions. The day ended with the new tires installed but the truck spent the night on the alignment rack.
That evening after dinner, I went out into the garage and fired up the propane torch and put a lot of heat on the old, original tie rods that we removed in our driveway. Got them apart and compared the inner tie rods with the spare set for the Yukon, they were not cut down 1/2 inch, they were cut down 3/4 of an inch! I emailed the shop my findings and received a reply in the morning. When my daughter brought the truck home the next night, she relayed to me that the shop replaced the inner tie rods on their dime as they cut down the originals too much and so they replaced them. They were supposed to replace the jam nuts with the Rough Country tie rod sleeves but they cut those down so much as to be worthless.
Seems to me that these experts in installing lift kits, went through a learning curve! Like most women, my daughter is not interested in the details and didn't ask for the alignment sheet but did ask for the old parts back. She's happy with the way it drives, steering wheel is straight, goes down the road straight and tires are properly balanced and rotated.
Went to initiate a TPM learn and the Tech-2 said the CANdi module was not attached, even though it was recognized on the start up screen and the green light was on, flashing. Same thing in the Yukon. Spent an hour passing and failing tests, swapping cards, cables, adapters, etc. and then had to pack it in for the night after injuring my back again. Will test it out tomorrow in the truck. If the problem persists, I guess we'll order up a new CANdi and maybe an ODBII adapter. Started to look at MDI2 adapters in anticipation of a new generation of vehicles coming into the driveway someday. We shall see.
For those reading this who are considering the purchase of a Tech-2, don't let this dissuade you. This machine has seen near continuous use for almost five years, often times for hours at a time. It's been left in the hot truck for weeks at a time, dropped, kicked, stepped on, etc. It's a tough piece of equipment.
Wanted the puddle lights to be a little brighter. Housings are good, still seals well, no yellowing or bugs inside. Ordered some Philips Ultinon 194WLED bulbs and put them in. They are directional, so if you don't see them turn on, flip the bulb. A little bit brighter than the 13 year old bulbs, nothing obnoxious and the light is white. They also offer, Amber, Blue and Red LED bulbs.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
I used the Sylvania LEDs in my puddle and license plate lights. Nice upgrade.
St. Louis
How hard is it to get to these bulbs in the mirrors? I've never really looked closely at them. Does the lens just pop off or unscrew?
Foggy
KS
Does anyone know the actual bulb part # for this puddle light ???
I want to replace mine, but not necessarily with the led's... Maybe just upgrade
to a "better" bulb... thanks
I can't find this particular bulb # listed on RA or Oreilly
They are 194s. I like Philips bulbs, they last a long time. With them you have two options, a Long Life 194NALL and 194NA for the OE quality. The latter is what I run for all the bulbs in mine save for those LED puddle lights we're trying out.
Was looking for stone guard film for the mirrors like the Sierra has and came across a closeout of genuine chrome mirror caps for $28 delivered so I grabbed them up. Truck originally came with them and somewhere along the way they were changed. Not a fan but they were cheap and will allow me to either clean up the bug guts from the black ones or get them repainted.
Woke up to this at 31 degrees this morning. Hadn't seen this in a long time. See the front on the roof of the truck and on the neighbor's across the street? Old hat for you Yanks but not something we see down here!
On a sad note, tractor pulls have come to our area but my rig is shod with highway tires now! Always wanted to do that at least once.
The new CANdi module arrived today, I hooked it up to the Yukon and it worked in both the Engine and Body modules. Later on, I hooked it up to the Sierra and the same error came up again, the Splash screen said the CANdi was there but after building the truck and going into the Body module and error message came up and said it was not attached! Oh no!
So we connected and disconnected all the cables, now the CANdi is not even recognized on the splash or start up screen. Then we swapped cables and OBDII adapters still no go. So then I had an idea, that old OBDII adapter that came with it, never worked, hooked it up and it talked to the truck just fine! It has gold contacts and is shaped different and has a different part number than the others, one was a replacement from the company purchased from, the other two were purchased off Amazon. One was lost in a field helping a guy out so just 3 are left. Anyway, it's just weird! That thing didn't work worth a lick 5 years ago, kept meaning to throw it out but glad I didn't now.
Well, I ought to hook it up to the Yukon but it's getting too cold outside now, it's a chilly 66 outside! LOL
Well, I'm not sure where this machine stands. Is it fixed and fully operational or intermittent? Went out to the Yukon this time and the CANdi was recognized on the splash screen and then it said no go when it tried to get into a module. Started resetting cables, connections, PCMCIA cards (have two) and even put the old CANdi back on. Of course, then the gold pin OBDII stopped working so had to swap it out too. Finally got it working with the old VCI Module, the old CANdi module and only one of the three OBDII adapters, one of the Amazon ones. Didn't have the keys to the Sierra but we connected and disconnected the adapter to the truck and wiggled all the connections and wires and it kept working even after being turned on and off. I think the flu everyone has had has now come my way, getting the sniffles and tired, no more playing with that thing today.
My daughter Julia got some RVinyl from Santa Clause this past Christmas and had some time off today today to cover some of the Sierra's interior trim pieces.
FYI: Both rear window switches gave up the ghost. I bought some replacements that were lighted, same as the ones in the Yukon XL, and they do not light up in the Sierra but they function just fine. The part number is 22895545 and I buy them from this guy: https://www.ebay.com/itm/333662102772 - Switch-Doctor.
Just finished an eleven hour run to rescue our two youngest daughters and their friends after the transmission in the Sierra went out. They made it to the truck meet but nobody had diagnostic tools. P0796 and she went into limp mode. It's under warranty so this won't be a kitchen table rebuild of the TECHM and valve body. Will know more later on, going to hit the rack soon.
justinakay79
