Monz11
thinking of changing out my K&N FIPK, with a different air filter system, since I'm boost it with the Maggy, the tube wont fit...what's everybody running?
External cooler cools more than the in-rad cooler. If it went into the external cooler first, then to the rad cooler, the trans fluid would get heated back up. Also, the rad cooler cools it first so the external cooler has less heat to remove, making it work even better.
The Magnuson isn't designed to use the factory air box?thinking of changing out my K&N FIPK, with a different air filter system, since I'm boost it with the Maggy, the tube wont fit...what's everybody running?
I didn’t make the rules!Damn Mark, just can't trust that the man did what he said? lol I smell trust issues!![]()
I was 44….f*ck I’m old.22years ago I was in 5th grade.![]()
Whipple supplied a tube to attach to the factory air box so I had to buy a used factory air box. Isn’t the Magnuson tube designed the same way? They I just did the mod to enlarge the fender side where it draws air in.thinking of changing out my K&N FIPK, with a different air filter system, since I'm boost it with the Maggy, the tube wont fit...what's everybody running?
fender mod? must check this out so I can do the sameWhipple supplied a tube to attach to the factory air box so I had to buy a used factory air box. Isn’t the Magnuson tube designed the same way? They I just did the mod to enlarge the fender side where it draws air in.
Edit: sorry for multiple posts but my notifications stopped again so I’m playing catch up.
The volant version can have an air scoop attached to the bottom to grab air from under the bumper on the pickups. Wonder if it would work on the wagons?The Magnuson isn't designed to use the factory air box?
I have the Corsa intake which I guess is also sold as volant, and the way that air box was designed I could have left the factory intake tube if you wanted to do that for some weird reason.
And since the Whipple is designed for the factory air box, I've seen other people able to use the Whipple intake tube right into their Corsa intake box.
I'm hoping that's true by the time I put it on.
Should scream pretty damn good
Damn you Dub. Every time I see that post of yours I remember I need to add that new foam seal, and every time there’s some reason why I don’t want to do it right now. Like now it’s winter.
Yes.Is this for the factory air box?
Did you have to plug anything in the OBD port for the HU to show that data?it's a pioneer nav unit, in the nav settings there is a setting to record drive data, then after (or during) a drive the data is shown under the "useful information" tab.
That foam replacement worked very well on my desert trip to the desert.Damn you Dub. Every time I see that post of yours I remember I need to add that new foam seal, and every time there’s some reason why I don’t want to do it right now. Like now it’s winter.![]()
What other kind of a trip to the desert is there other than a desert trip to the desert? Is there a non-desert trip to the desert ?That foam replacement worked very well on my desert trip to the desert.
The recent kindWhat other kind of a trip to the desert is there other than a desert trip to the desert? Is there a non-desert trip to the desert ?![]()
KOH trip to the desertWhat other kind of a trip to the desert is there other than a desert trip to the desert? Is there a non-desert trip to the desert ?![]()
It was non-desert?The recent kind
