Rear main info
Byoung1330
Cookeville tn
What’s up y’all. Just had some info about my rear main. I developed a leak at around 230k. I ran castrol bout the whole time I had it. Someone told me to switch to Mobil 1. Never again. After about 2 oil changes it started leaking like crazy. Switched back to castrol an the leak never went away. Tried every stop leak on the market with no success. I had oil on bell housing. Down starter bolts. All that. Couldn’t see oil on fly wheel through inspection cover. Changed valve cover gaskets. Oil pressure sensor. Crank sensor. Oil pan gasket. Everything. So by then I knew it was rear main. Never done a job that big. Biggest I ever done was install my lowering kit an changed every piece of suspension on my Tahoe u can change. It’s all new. Also did a new timing chain an oil pump. But didn’t wanna drop tranny especially with it being so low. Well I said screw it an went for it. Bought me 2 long extensions off Amazon an 15mm and 13mm deep well swivel sockets. Bought tranny Jack from harbor freight. Took it back when I was done lol. The cover. The gasket an a barbell while I was in there. At the end of my y pipe I don’t have a flange to unbolt so had to cut it. Clean cut welded back up after I was done. Anyway if u guys have this problem don’t be scared if I can do it u can do it. Took me about 12 hours. That’s cleaning all bolts an crossmember an taking my time not to mess anything up. I haven’t had a drop of oil since. Been 4 days now.
Byoung1330
Byoung1330
Cookeville tn
Forgot to add I even pulled intake. Even tho I had it off a year prior. Just to take the valley pan gasket out the equation. Didn’t stop the leak.
I'm reading this as the detergent additives package in Mobil1 being very effective at dissolving and removing buildup. This is how the rumors spread that "synthetic will make your engine leak oil" as if it's an inherent negative factor of using synthetic oil. Technically, it can make an older engine leak, but it's not because it's synthetic. It's because the conventional oil and/or the lack of timely oil changes allowed sludge/gunk to build up, even if just a thin film, on the internal surfaces of the engine, mostly in the finer creases. Also, the molecules of conventional aren't as "fine" as those of synthetic. It could also be that the conventional oil doesn't have as robust of a detergents package as that in the more expensive synthetic oil.
The buildup and "coarser" molecules of the conventional oil masked the worn seal(s), preventing leak(s). Running the Mobil1, with its powerful detergents, cleaned away the buildup. The Mobil1, with its finer molecules and now lack of buildup to dam it, leaked past the seal(s).
drakon543
well above argument about mobil 1 aside when a rear main is ready to start leaking its all or nothing and will only progressively get worse. nothing you add to it will help much if at all because its a rotational seal. making it to 230k is more suprising for some as a rear main can start as early as 150k on older rigs.
Agreed, once your rear main starts to go it’s only a matter of time regardless of what oil you’re running. I always figure if I have to rely on stop leak, I wonder where else it’s it’s gumming things up. I would never run it unless it’s a last desperate measure and the engine is at the end of its life. Pulling the trans is a bear of a job for the average backyard mechanic but it’s not technical, just physically difficult. And while it’s out you should consider replacing the torque converter just because it’s the other component that could fail down the road that requires pulling the transmission. For me, it would be worth the peace of mind. When I did mine I was replacing the transmission with a heavy duty built unit so the TC was a new billet one anyway but if it wasn’t I would have bought a new stocker. Also inspect the flexplate for cracking or just replace it too. You don’t want to pull that trans again, believe me. Be sure to read up on the alignment of the new rear main as it’s critical, and misalignment will cause the new seal to wear prematurely. There’s a tool made for it or better yet, buy the AC Delco rear cover with rear main already installed in it and follow the instructions. It’s pretty foolproof that way and you get a new rear cover seal in the deal.
Byoung1330
Byoung1330
Cookeville tn
Awesome job. I have done everything to my truck including the trans (3 times lol) and rear main while I was in there. It’s just turning bolts like everything else except you’re on your back unless you have a lift. Which I don’t.
No the next day I couldn’t move being on my back that long. My neck felt broke lol
Byoung1330
Byoung1330
Cookeville tn
An yes I was afraid of the Mobil 1 cleaning out gunk an cleaning out spots holding the seals together an it did lol
MassHoe04
Western MA
Sometimes cleaner is not better. I have seen vehicles with years of neglect and no leaks and as soon as someone decides to flush, clean or run some kind of products with detergents in them to make internals all shiny like new... Things start ******* fluids all over the place!
Maybe the gradual build-up of deposits counter-act the wear on some of those seals? Building surfaces up as things wear down... Maybe a crazy theory. Or is it???
Seriously, though... There was one particular oil from Mobil that had some kind of seal conditioners that seemed to have done wonders in "restoring" flexibility of RMS, stopping the leaks for good. Not filling voids like leak stopper products, but getting the old hardened seal to soften up a bit and seal against the crank shaft better.
I went looking for posts on the WranglerForum.com, but couldn't find what I originally saw there. I want to say the oil was "Mobil Super High Mileage". https://www.amazon.com/Mobil-Super-...t=&hvlocphy=9001765&hvtargid=pla-569800672003
St. Louis
I always thought the "high mileage" line of oil (Mobil1 High Mileage for example) contained additives to recondition seals.
robhotdog
Good job! What's a Barbell?? Mines the same but its 4x4...yours was cake! I'm still adding allittle oil for now..
Teamiez
I got mine done under the 3 month 1000 mile lemon law warranty when I bought mine from a Chevy dealer January of 2015 @ 97,000 miles, they also did the oil pressure sensor & pulled the intake & broke it so got a new intake and gaskets out of that deal as well.
MassHoe04
Western MA
Props to anyone willing to tackle that job in the driveway! RMS is a job that can go smoothly or NOT... If the service books say 8 hour job, I just know it would be a solid 20 hours over two days and a whole lot of swearing in my driveway.
When I was a Jeep owner, the joke on the forums among people with RMS leaks, who were procrastinating doing the repair was something like this:
"Consider it a perpetual oil change. Just keep topping it off and after a month or so, your oil will have been completely changed out! - You don't have to change the oil filter either, because the oil never gets old..."
MoundMedic7
